I would like to convert pb file which is in ssd_mobilenet_v1_quantized_300x300_coco14_sync to uff file. So, I tried use convert_to_uff.py. But, I could not do this work.
$python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py tflite_graph.pb -o ssd_mobilenet_v1.uff -O NMS -p config.py
My config.py is config.py.txt (2.0 KB)
The error message are following:
2020-11-22 17:40:44.038248: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Loading tflite_graph.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py:274: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.15.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 143, in <module>
main()
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 139, in main
debug_mode=args.debug
File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py", line 276, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py", line 153, in from_tensorflow
pre.preprocess(dynamic_graph)
File "/home/totti/09.DeepStreamTotti/ssd_mobilenet_v1_quantized_300x300_coco14_sync_2018_07_18/config.py", line 56, in preprocess
dynamic_graph.find_nodes_by_op("NMS_TRT")[0].input.remove("Input")
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/internal/containers.py", line 296, in remove
self._values.remove(elem)
ValueError: list.remove(x): x not in list
How can I convert pb file to uff file? Thank you for your support.
The error indicates the layer for removal mentioned in the config.py file doesn’t exist.
Could you delete following two lines and try it again?
all_assert_nodes = dynamic_graph.find_nodes_by_op("Assert")
dynamic_graph.remove(all_assert_nodes, remove_exclusive_dependencies=True)
Thank you for your support! I remove 2 lines from config.py. But, the error was same:
2020-11-23 13:12:35.307498: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
main()
Sorry that there is some mistake. The error is caused by the line below:
Please remove the line instead.
