convert pb to uff
hi,
I tried to use convert_to_uff.py to convert my pb model to uff. But I get these errors:
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 233, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 181, in from_tensorflow
debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 41, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 222, in parse_tf_attrs
return {key: cls.parse_tf_attr_value(val) for key, val in attrs.items() if val is not None and val.WhichOneof('value') is not None}
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 222, in <dictcomp>
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 218, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 190, in convert_tf2uff_field
return TensorFlowToUFFConverter.convert_tf2numpy_dtype(val)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 103, in convert_tf2numpy_dtype
return tf.as_dtype(dtype).as_numpy_dtype
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py", line 128, in as_numpy_dtype
return _TF_TO_NP[self._type_enum]
KeyError: 20
Then I search the problem and answer for this: https://devtalk.nvidia.com/default/topic/1049399/jetson-tx2/tensorflow-model-to-tensorrf-uff-model-convert-error/
and then I tried tf-trt to convert my model with my own pb file( converted from .h5 model file), but then I got these errors:
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 426, in import_graph_def
    graph._c_graph, serialized, options)  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: Input 0 of node bn_Conv1/cond/ReadVariableOp/Switch was passed float from bn_Conv1/gamma:0 incompatible with expected resource.
During handling of the above exception, another exception occurred:
  File "pb2uff.py", line 17, in <module>
    trt_graph = trt.create_inference_graph(input_graph_def=frozen_graph,outputs=output_names,max_batch_size=1,max_workspace_size_bytes=1<<  25,precision_mode='FP32',minimum_segment_size=50)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow/contrib/tensorrt/python/trt_convert.py", line 333, in create_inference_graph
    importer.import_graph_def(input_graph_def, name="")
  File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 430, in import_graph_def
    raise ValueError(str(e))
ValueError: Input 0 of node bn_Conv1/cond/ReadVariableOp/Switch was passed float from bn_Conv1/gamma:0 incompatible with expected resource.
Then how could I solve this problem? thanks
Usually, this issue is cased by the incompatibility cross different TensorFlow version.
Do you use TensorFlow v2.0 to generate the .pb file?
solved.
Hi, how did you solve this problem?
