We are trying to evaluate TOPS in Jetson AGX Orin Module.
We tried making use of GLMARK2 app which dynamically loads GPU till 90 % (as per my observation) . Also i have run a high load script which loaded 99% GPU but unfortunately i couldnt get the TOPS value from that
I am new to this field, wanted to know how the TOPS value can be co related with GPU load percentage, If the GPU is loaded for 100% can we co relate it to the max TOPS achievable in that power configuration
As per the below stats from NVIDIA for the 30W configuration, the total TOPS can go
upto 130 for 30W configuration. Just need to understand how this was bench marked and is there a way where we can test the same by running utility or the DL applications. If that so, please share the details to validate the same
Regards,
Chandan
