For example, 4 .uff files trained with tensorflow,How to deploy with deepstream?
Please help me!
[/quote]
Please help me!
[/quote]
You can check this sample which also use uff model first:
/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_SSD
In general, you will need to define the following parameters in the property group:
uff-file=sample_ssd_relu6.uff model-file=VGG16_faster_rcnn_final.caffemodel
uff-input-dims=3;300;300;0 proto-file=faster_rcnn_test_iplugin.prototxt
uff-input-blob-name=Input
output-blob-names=MarkOutput_0
Here is our document for your reference:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_custom_model.html%23wwpID0ERHA
Not sure what kind of your model is, is it a classifier or a detector?
For multiple classifiers, you can just enable them with multiple secondary-gie components.
Check this configure file as an example:
/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
I use the platform type tx2,can provide a sample source code for multiple models?
[/quote]
Deepstream is available for TX2.
You can install it directly from the sdkmanager.
Both uff and multiple model are supported by deepstream-app.
You can run it with this command for multi-model use case:
deepstream-app -c [your configure file]
The configure file sample of uff and multiple models can be found in:
Please update the model information(ex. path, output name, …) based on your use case.
If you are finding the source code of deepstream-app, you can also find it in this folder:
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-app/
How to deploy multiple models with deepstream-5.1 ? and how can we do same things in python application ?
How to use custom multiple models with deepstream-5.1 in python binding application ?
Hi shankarjadhav232,
Please help to open a new topic. Thanks
