Description
I’ve asked a question here.
So far, I’ve done the calibration for my Unet model’s int8 inference with the community’s help from github.
The process of my calibration is as below:
- convert keras model to .onnx with explicit batch=1 is set
- read the directory path of calibration data
cv::imreadthe input data and convertcv::Matto datatypefloat- the calibration class do the rest
I’ve tested three different cases with the same model structure, trying to figure out the SOP of doing calibration,
but I couldn’t find a standard way to do so…
In my case, adjusting the beta value of cv::Mat::convertTo() can result to very different result.
Here are the cases I’ve tested with the best parameter to get the closest result with FP16 one:
- case A:
model input size: 1920 x 1920 x 1
pre-process of calibration:
cv::Mat img = cv::imread(imgPaths[j]);
img.convertTo(img, CV_32FC(MD_size[2]), 1 / 255.0, -0.45);
result of inference: data with value 0 and 0.5
- case B:
model input size: 1664 x 288 x 1
img.convertTo(img, CV_32FC(MD_size[2]), 1 / 255.0, 0);
result of inference: data range from 0 to 1
- case C:
model input size: 512 x 960 x 3
img.convertTo(img, CV_32FC(MD_size[2]), 1 / 255.0, 2.5);
If I didn’t adjust the beta value, the result of case A and case C would cause too many overkill at the OK part.
However, adjusting beta value is a trial-and-error solution for me.
(Since I didn’t use that beta value while inferencing with reading data and convert to float)
So, I want to know that:
- Am I doing right with the calibration part’s pre-processing?
- Why the result of inference’s data range is different?
(For one case, it ranges from 0 to 1; for others, they’re value with 0 and 0.5)
Environment
TensorRT Version: 7.0.0.11
GPU Type: RTX2080 Ti
Nvidia Driver Version: 451.82
CUDA Version: 10.0
CUDNN Version: 7.6.5
Operating System + Version: Windows10
Python Version (if applicable): 3.7.0
TensorFlow Version (if applicable): 1.13.1
PyTorch Version (if applicable): -
Baremetal or Container (if container which image + tag): -
Relevant Files
Steps To Reproduce
Focus on the part ONNX2TRT()
and this part
std::cout << "***USING INT8***\n";
config->setFlag(BuilderFlag::kINT8);
// provided by @le8888e at https://github.com/NVIDIA/TensorRT/issues/557
std::string calibration_imgs_list = Jconfig["cali_image_path"].get<std::string>();
std::string calibration_table_save_path = Jconfig["cali_save_path"].get<std::string>();
int8EntroyCalibrator *calibrator = nullptr;
calibrator = new int8EntroyCalibrator(1, calibration_imgs_list, calibration_table_save_path);
config->setInt8Calibrator(calibrator);
The int8EntroyCalibrator class done the calibration part.
Thanks in advance for any help or advice!
