How to enable asymetric padding in deepstream?
• Hardware Platform (Jetson / GPU). Nvidia T4 GPU
• DeepStream Version - 5.1 and 6.0
• JetPack Version (valid for Jetson only) –
• TensorRT Version. 8.0.1-1+cuda11.3
• NVIDIA GPU Driver Version (valid for GPU only) 460.32.03
• Issue Type( questions, new requirements, bugs) - QUESTION
In Gst-nvinfer — DeepStream 6.1.1 Release documentation there is a description of symetric-padding option in inference-engine configuration:
Indicates whether to pad image symmetrically while scaling input. DeepStream pads the images asymmetrically by default.
This suggests that there is a way to pad images asymmetrically in deepstream - I imagine bottom-right padding is the default. Unfortunately running this pipeline:
gst-launch-1.0 nvstreammux name=mux batch-size=2 width=608 height=608 ! queue ! nvinfer config-file-path=/mounted/data/models/yolo/yolo_gie_config_fp32_bs_1_608x608.txt ! queue ! nvstreamdemux name=demux \
    uridecodebin uri=file:///mounted/data/videos/horizontal.mov ! nvvideoconvert ! queue ! mux.sink_0 \
    uridecodebin uri=file:///mounted/data/videos/vertical.mov ! nvvideoconvert ! queue ! mux.sink_1 \
    demux.src_0 ! queue ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=/mounted/data/images/deepstream-streammux-set/src_0/horizontal.mp4 \
    demux.src_1 ! queue ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=/mounted/data/images/deepstream-streammux-set/src_1/vertical.mp4
With config:
[property]
gpu-id=0
num-detected-classes=2
net-scale-factor=0.00392156862745098
batch-size=2
model-engine-file=/mounted/data/models/yolo/mmdet/yolo_fp32_bs_2_608x608_trt.engine
labelfile-path=/mounted/data/models/yolo/labels.txt
gie-unique-id=1
operate-on-gie-id=1
interval=0
### Integer 0: FP32 1: INT8 2: FP16
network-mode=0
offsets=0.0;0.0;0.0
output-blob-names=num_detections;boxes;scores;classes
parse-bbox-func-name=NvDsInferParseMmdet
custom-lib-path=/root/space/amirstan_plugin/build/lib/libamirstan_plugin.so
### Integer 0: RGB 1: BGR 2: GRAY
model-color-format=0
### Integer 1=Primary 2=Secondary
process-mode=1
### Integer 0: Detector 1: Classifier 2: Segmentation 3: Instance Segmentation
network-type=0
maintain-aspect-ratio=1
symmetric-padding=0  - does not work for some reason
infer-dims=3;608;608
### Integer 0: OpenCV groupRectangles() 1: DBSCAN 2: Non Maximum Suppression 3: DBSCAN + NMS Hybrid 4: No clustering
cluster-mode=4
scaling-filter=1
### Integer 0: Platform default – GPU (dGPU), VIC (Jetson) 1: GPU 2: VIC (Jetson only)
scaling-compute-hw=1
### Integer 0:NCHW 1:NHWC
network-input-order=0
### Dumb parameters which shouldn't matter but they do
workspace-size=500
classifier-threshold=0.1
[class-attrs-all]
### threshold=0.1  - deprecated
pre-cluster-threshold=0.1
post-cluster-threshold=0.1
nms-iou-threshold=1.0
## disbles clustering whatsoever
group-threshold=0
## 0 disables the clustering functionality
minBoxes=0
detected-min-w=16
detected-min-h=16
detected-max-w=0
detected-max-h=0
topk=100
roi-top-offset=0
roi-bottom-offset=0
Unfortunately, symmetric-padding flag does not work. The output is:
Unknown or legacy key specified 'symmetric-padding' for group [property]
and the output video is squashed instead of padded. when enable-padding flag is enabled on streammux element the padding is done symetrically. Is there a way to do it asymmetrically in deepstream ?
nvinfer is source code release. Can you have a check the source code?
Hi, I have checked out the source code - it seems that container nvcr.io/nvidia/deepstream:6.0-ea-21.06-devel does not support this flag but the proper deepstream-6.0 container - nvcr.io/nvidia/deepstream:6.0-devel does. I have tried to switch this flag on and off in infer_config.txt but it does not seem to have any effect.
The question persists - how to enable asymmetric padding in deepstream ?
Can you add some log to check why it does not any effect?
How should I do that in the case of deepstream - should I export the variable GST_DEBUG=3 ?
Suppose you have the nvinfer source code. Can you add some log in the source code?
I have read the source code of nvinfer plugin. Seems that input-tensor-meta variable set to TRUE (by default) blocks any changes to images in buffer. When trying to set input-tensor-meta to FALSE or 0 deepstream prints out:
Unknown or legacy key specified 'input-tensor-meta' for group [property]
Which is not in line with documentation of nvinfer element - Gst-nvinfer — DeepStream 6.1.1 Release documentation
Can you tell me how to enable asymmetric padding in deepstream instead of reading source-code?
This is my pipeline inside of nvcr.io/nvidia/deepstream:6.0-devel container which you can easily replicate on your side (all needed resources are already inside of this container) :
 gst-launch-1.0 nvstreammux name=mux batch-size=1 width=608 height=342 ! queue ! nvinfer config-file-path=/mounted/my_config.txt input-tensor-meta=0 batch-size=1 ! queue ! nvstreamdemux name=demux \
    uridecodebin uri=file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4 ! nvvideoconvert ! queue ! mux.sink_0 \
my_config.txt :
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel
proto-file=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.prototxt
model-engine-file=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
labelfile-path=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/labels.txt
int8-calib-file=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/cal_trt.bin
force-implicit-batch-dim=1
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
symmetric-padding=1
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
cluster-mode=2
input-tensor-meta=0
[class-attrs-all]
pre-cluster-threshold=0.2
topk=20
nms-iou-threshold=0.5
Output from the pipeline:
root@9329ce241db4:/mounted#  gst-launch-1.0 nvstreammux name=mux batch-size=1 width=608 height=342 ! queue ! nvinfer config-file-path=/mounted/weird_config.txt input-tensor-meta=0 batch-size=1 ! queue ! nvstreamdemux name=demux \
(gst-plugin-scanner:14): GStreamer-WARNING **: 12:26:22.224: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14): GStreamer-WARNING **: 12:26:22.233: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
Setting pipeline to PAUSED ...
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:02.662365186    13 0x55eff8ba8160 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:02.662424770    13 0x55eff8ba8160 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:02.662464525    13 0x55eff8ba8160 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:14.212304120    13 0x55eff8ba8160 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x608x608
1   OUTPUT kFLOAT conv2d_bbox     16x38x38
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x38x38
0:00:14.216990067    13 0x55eff8ba8160 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:/mounted/weird_config.txt sucessfully
Pipeline is PREROLLING ...
WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:mux: Rounding muxer output height to the next multiple of 4: 344
Additional debug info:
gstnvstreammux.c(2803): gst_nvstreammux_change_state (): /GstPipeline:pipeline0/GstNvStreamMux:mux
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:02.471190176
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I am doing a really simple pipeline and trying to enable simple thing in accordance with documentation - I don’t understand why is it so hard to enable such a simple feature?
I don’t see nvdspreprocess in your pipeline, please don’t use “input-tensor-meta”.
How can you know “symmetric-padding” don’t take effect?
I know that symmetric-padding does not take effect because as you can see in the pipeline I am saving the frames that enter and leave nvinfer element as video-file - I have tried various configurations - you can try them yourself and verify my claims.
Can you explain how to use nvdspreprocess element in this pipeline to enable asymmetric padding?
Suppose “symmetric-padding” is for scale video to model size and then inference on it. The output of nvinfer shouldn’t effect by “symmetric-padding”.
ok, so in that scenario streammux element should only be responsible for batching - as you can see I have two video sources - one vertical and one horizontal - output resolution of streammux must be specified (so it must be either vertical or horizontal) - how to overcome this issue ?
Yes. streammux will scale to same resolution. You can enable padding to keep ratio.
Yes, and this padding is always symmetric - can you provide me a simple pipeline with asymmetric padding enabled? Just a simple example will do
streammux only support symmetric padding currently. One possible solution is process video based on your requirement before feed to streammux.
