nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
MAX96712: Revision 2 detected
MAX9295: Revision 8 detected!
Sensor IMX390 Rev 0 RGGB detected!
[InitializeIspConfigData:337] No Camera Specific Configuration found: Using default settings, Image quality is not supported!
Enter ‘q’ to quit the application
Output FPS
Sensor12_Out1 25.9971
Sensor12_Out2 25.9971
Output FPS
Sensor12_Out1 29.9966
Sensor12_Out2 29.9966
Output FPS
Sensor12_Out1 29.9968
Sensor12_Out2 29.9968
Output FPS
Sensor12_Out1 29.997
Sensor12_Out2 29.997
Output FPS
Sensor12_Out1 29.9969
Sensor12_Out2 29.9969
Output FPS
^COutput FPS
Sensor12_Out1 29.9922
Sensor12_Out2 29.9922
So, I have a camera_overrides.isp file for this IMX390 sensor and I want to install it in order to improve the output images from the ISP, where should I place the camera_overrides.isp file?
Yes, We got the drivers from Sony along with the camera_overrides.isp file but the ISP tuning file is detected only if the current directory (directory that has the capture application) contains the isp tuning file.
Output when there is not an isp file in the current directory:
./nvmipp_raw --disable-egl --showfps -cf /home/nvidia/drive-t186ref-> linux/samples/nvmedia/ipp_raw/ddpx-a.conf -c IMX390-TRIO-GH
Max96712 Rev 2 detected!
MAX96712 Rev 2 manual adaptation on the link 0(31)
Sensor IMX390 Rev 0 RGGB detected! [InitializeIspConfigData:337] No Camera Specific Configuration found: Using default settings, Image quality is not supported!
Type “h” for a list of options
Output when there is a camera_overrides.isp file in the current directory:
./nvmipp_raw --disable-egl --showfps -cf /home/nvidia/drive-t186ref-linux/samples/nvmedia/ipp_raw/ddpx-a.conf -c IMX390-TRIO-GH
Sensor IMX390 Rev 0 RGGB detected! Reading camera_overrides.isp override file
Is there a system path to place the isp tuning files?
DRIVE Software 10.0 (DRIVE OS 5.1.6.1) has no a centralized place for ISP files.
However, for the upcoming release, it will have NITO (NVIDIA ISP Tuning Object) file as the replacement of ISP file and /opt/nvidia/nvmedia/nit/ as its default path. Thanks!
