How to Enable SD Card on TX2 NX
I am trying to enable the SD Card on a custom carrier board for the TX2 NX.
I have added the following to my device tree:
   sdhci@3440000 {
            status = "okay";
            cd-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(X, 4) GPIO_ACTIVE_HIGH>;
            nvidia,cd-wakeup-capable;
            /delete-property/ non-removable;
            vmmc-always-on;
            nvidia,sd-device;
    pinmux@2430000 {
                pinctrl-names = "default", "drive", "unused";
                pinctrl-0 = <&pinmux_default>;
            pinmux_default: common {
                    sdmmc3_clk_pg0 {
                            nvidia,pins = "sdmmc3_clk_pg0";
                            nvidia,function = "sdmmc3";
                            nvidia,pull = <TEGRA_PIN_PULL_NONE>;
                            nvidia,tristate = <TEGRA_PIN_DISABLE>;
                            nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                    sdmmc3_cmd_pg1 {
                            nvidia,pins = "sdmmc3_cmd_pg1";
                            nvidia,pull = <TEGRA_PIN_PULL_UP>;
                    sdmmc3_dat0_pg2 {
                            nvidia,pins = "sdmmc3_dat0_pg2";
                    sdmmc3_dat1_pg3 {
                            nvidia,pins = "sdmmc3_dat1_pg3";
                    sdmmc3_dat2_pg4 {
                            nvidia,pins = "sdmmc3_dat2_pg4";
                    sdmmc3_dat3_pg5 {
                            nvidia,pins = "sdmmc3_dat3_pg5";
Our design uses the card detect pin but always applies power to the SD Card.
When the card is inserted I get many errors like the following:
mmc1: CMD CRC or end bit error, int mask 0x40000
I also see the following when checking /sys/kernel/debug/mmc1/ios
clock:          0 Hz
vdd:            0 (invalid)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     0 (off)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
signal voltage: 0 (3.30 V)
driver type:    0 (driver type B)
please check this thread.
Thank you for pointing me to that thread. the fixes mentioned worked. My SD Card hotplugs and is writable. here is my final devicetree node:
sdhci@3440000 {
        status = "okay";
        /delete-property/ force-non-removable-rescan;
        nvidia,sd-device;
        vmmc-supply = <&spmic_sd3>;
        mmc-ocr-mask = <3>;
        sd-uhs-sdr104;
        sd-uhs-sdr50;
        sd-uhs-sdr25;
        sd-uhs-sdr12;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
