We are using sdmmc3 on the carrier board, but we cannot see this device,
Some similar problems were found from forums, but none of them can solve the problem of not being able to catch SDCard.
How can we use the SDcard on sdmmc3?
Here are the dmesg logs:
anycon@tegra-ubuntu:~$ dmesg | grep sd
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt ug
[ 0.738390] iommu: Adding device 3460000.sdhci to group 6
[ 0.739015] iommu: Adding device 3440000.sdhci to group 7
[ 0.802869] GPIO line 266 (vcc-ssd-en) hogged as output/high
[ 0.818006] vdd-sdmmc3-sw: 3300 mV
[ 0.818380] vdd-1v8-sd: 1800 mV
[ 0.977556] vddio-sdmmc1-3v3: at 3300 mV
[ 4.321178] sd: No Scsi addr parsed to reserve index
[ 5.362853] sdhci: Secure Digital Host Controller Interface driver
[ 5.368269] sdhci: Copyright(c) Pierre Ossman
[ 5.372715] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.379429] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 5.390585] sdhci-tegra 3440000.sdhci: Got CD GPIO
[ 5.397499] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 5.403996] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 321
[ 5.435798] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.455842] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.477595] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 7.044345] vdd-sdmmc3-sw: disabling
[ 7.044451] vdd-1v8-sd: disabling
[ 7.325166] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.389648] systemd-sysv-generator[2203]: Native unit for gpsd.service already exists, skipping. dts_changes_for_sd.txt (2.3 KB)
We have done the attached changes in dtsi for the same.
I think so, other changes are also getting reflected. I am attaching the tegra194-p3668-all-p3509-0000.dtb.txt (192.9 KB) dtb file here for your reference.
The card enumeration is even not starting. If you hotplug the card and dmesg does not show anything new, then please check the signals from cd gpios or your vmmc-supply.
