The USB2_EN_OC(pin A19) can be used to enable USB Vbus on TX1.But on TX2, it sill in “0” status. How to use it?
You can find in OEM DG of TX1/TX2 that it is not recommended to use this pin as it is unconnected in module.
And how to enable the “USB_SS#2" on USB_SS1 pin? I have change the ODMDATA to 0x7090000
Please read
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1
Start_L4T_Docs.html → PDF Documents → Platform Adaptation and Bring-Up Guide: Tegra Linux Driver Package for Jetson TX2 (PDF) → USB Lane Mapping
And ensure device tree, ODMDATA, and cfg files are correct.
