I would like to encode H264 file with only IDR Frame.and I set the pipeline like this:
appsrc name=appsrc ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! nvvideoconvert ! video/x-raw(memory:NVMM), format=NV12, width=1920, height=1080,framerate=(fraction)30/1 ! nvv4l2h264enc control-rate=constant_bitrate bitrate=24000000 iframeinterval=0 profile=0 maxperf-enable=true insert-sps-pps=true insert-vui=true ! appsink name=appsink
but it seem not enough. I can not found the option idrinterval.
And my nvv4l2h264enc version is 1.14,how can I use:
Element Actions:
"force-IDR" : void user_function (GstElement* object);
The option is demonstrated in 01_video_encode:
--alliframes Enable all I-frame encoding [Default = disabled]
It is not in nvv4l2h264enc plugin. You may refer to 01_video_encode, apply it to source of gst-v4l2, and rebuild/replace:
/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
All source code are in
https://developer.nvidia.com/embedded/linux-tegra
[L4T Driver Package (BSP) Sources]
If you use previous release, please go to
https://developer.nvidia.com/embedded/linux-tegra-archive
Thanks for your reply.I can not found the alliframes option from 01_video_encode. Can you send me a link to download the sample? Is 01_video_encode the nvv4l2 sample?
Please check if you see the sample in
/usr/src/jetson_multimedia_api/samples/01_video_encode
If not, please install the samples through SDKManager
