I am trying to use nveglstreamsrc with omxh264enc to encode the output of my opengl application. I followed the procedure given in the following links.
https://github.com/DaneLLL/simpleEGLStreams_producer
https://github.com/DaneLLL/gstreamer_eglstreamsrc
I was able to connect nveglstreamsrc to nvoverlaysink and it worked fine.
But when I use omxh264enc with nveglstreamsrc, I face the following issue.
Using launch string: nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=I420, width=1280, height=720, framerate=30/1 ! omxh264enc bitrate=2500000 name=video_enc iframeinterval=15 profile=high control-rate=4 ! queue ! video/x-h264, stream-format=byte-stream ! fakesink
NVEGLStreamProducer: start_eglstream_producer ++
eglDisplay Handle created
EGLStream initialized
NVEGLStreamProducer: start_eglstream_producer –
display 0x645100, stream 0x6686a1
Thread created
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Obtained EGLConfig and EGLContext
Bound layer to rendering surface
eglSwapBuffers_wrapper—: 1
NvMSEncCheckInputSurface:327: Only Blocklinear and Pitch surface format allowed
VENC: VideoEncInputProcessing: 4376: VideoEncFeedImage failed. Input buffer 0 sent
VENC: NvMMLiteVideoEncDoWork: 5001: BlockSide error 0x4
Event_BlockError from 0BlockAvcEnc : Error code - 4
Sending error event from 0BlockAvcEnc0:00:00.669944218 3124 0x7f90001950 ERROR
I am using Tx2 with L4T28.2.1.
Can you anyone help me out?
Please add nvvidconv and try again.
nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=I420, width=1280, height=720, framerate=30/1 ! nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! omxh264enc ! ...
Hi DaneLLL,
Thanks for your quick response.
I tried with nvvidconv as suggested and I am still facing the same problem.
Please try the solution:
On r28.2/TX1, r28.2.1/TX2, please follow the steps:
Modify CUDA revision in Makefile:
GitHub - DaneLLL/simpleEGLStreams_producer
CUDA_PATH ?= /usr/local/cuda-9.0
Modify gstreamer pipeline:
GitHub - DaneLLL/gstreamer_eglstreamsrc
launch_stream
<< "nveglstreamsrc name=egl_src ! "
<< "video/x-raw(memory:NVMM), <b>format=RGBA</b>, width="<< w <<", height="<< h <<", framerate=30/1 ! "
<b><< "nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! "</b>
<< "omxh264enc bitrate…
Hi DaneLLL,
Thanks a lot for your inputs. I replaced the libgstnveglstreamsrc.so provided by you and used the launch_stream pipeline provided. Now i am able to use the encoder. It will be of great help if you can let me know if you an example for using the nvtee. I am able to get data only using the pre_src pad and not vid_src pad.
Thanks in Advance.
You may use tee plugin. Please refer to
You can utilize ‘tee’
$ gst-launch-1.0 uridecodebin uri=file:///home/nvidia/jellyfish-10-mbps-hd-hevc-10bit.mkv ! nvvidconv ! 'video/x-raw(memory:NVMM)' ! tee name=t ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=a.mp4 t. ! queue ! nvv4l2h265enc ! h265parse ! matroskamux ! filesink location=a.mkv
The pipeline would be like
nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=RGBA, width=1280, height=720, framerate=30/1 ! nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! tee name=t t. ! queue ! nvverlaysink t. queue ! omxh264enc ! ...
