I’m trying to use nveglstreamsrc on TX1, and tyied the following two codes:
https://github.com/DaneLLL/gstreamer_eglstreamsrc
https://github.com/DaneLLL/simpleEGLStreams_producer
But didn’t get them run. I modified a little bit with two pipelines, and printout some info:
The first one:
Using launch string: nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=I420, width=1280, height=720, framerate=30/1 ! omxh264enc bitrate=2500000 name=video_enc iframeinterval=15 profile=high low-latency=false control-rate=4 ! queue ! video/x-h264, stream-format=byte-stream ! fakesink
NVEGLStreamProducer: start_eglstream_producer ++
eglDisplay Handle created
EGLStream initialized
NVEGLStreamProducer: start_eglstream_producer --
display 0x64c490, stream 0x66f791
Thread created
NvEglStreamSrcInitializeEgl: Load library: libEGL.so
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Obtained EGLConfig and EGLContext
Bound layer to rendering surface
eglSwapBuffers_wrapper---: 1
NvMSEncCheckInputSurface:327: Only Blocklinear and Pitch surface format allowed
VENC: VideoEncInputProcessing: 4367: VideoEncFeedImage failed. Input buffer 0 sent
VENC: NvMMLiteVideoEncDoWork: 4989: BlockSide error 0x4
Event_BlockError from 0BlockAvcEnc : Error code - 4
Sending error event from 0BlockAvcEnceglSwapBuffers_wrapper---: 1
frame = 1
frame = 2
frame = 3
eglSwapBuffers_wrapper---: 0
frame = 4
frame = 5
frame = 6
frame = 7
and the second one:
Using launch string: nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=I420, width=1280, height=720, framerate=30/1 ! nvegltransform ! nveglglessink -e
Thread created
display 0x63c610, stream 0x65f6c1
Not supported input Rmsurface
frame = 1
frame = 2
frame = 3
frame = 4
frame = 5
frame = 6
frame = 7
Actually the producer is running, but eglSwapBuffers returns EGL_FALSE after some cycles.
What’s the problem?
DaneLLL
November 23, 2018, 2:15am
#2
What is your BSP revision?
Hi DaneLLL,
Thank you very much for the quick reply.
JetPack 3.1; L4T r28.1
And I also print out some more gst debug info for these two pipelines:
Using launch string: nveglstreamsrc name=egl_src ! video/x-raw(memory:NVMM), format=I420, width=1280, height=720, framerate=30/1 ! omxh264enc bitrate=2500000 name=video_enc iframeinterval=15 profile=high control-rate=4 ! queue ! video/x-h264, stream-format=byte-stream ! fakesink
display 0x64c380, stream 0x66f681
Thread created
===== MSENC =====
Sending error event from 0BlockAvcEnc0:00:00.716821927 2042 0x7f740012f0 ERROR omx gstomx.c:504:EventHandler:<video_enc> encoder got error: Bad parameter (0x80001005)
0:00:00.716893073 2042 0x640770 ERROR omx gstomx.c:276:gst_omx_component_handle_messages:<video_enc> encoder got error: Bad parameter (0x80001005)
0:00:00.716933906 2042 0x640770 ERROR omx gstomx.c:1293:gst_omx_port_acquire_buffer:<video_enc> Component encoder is in error state: Bad parameter
frame = 1
frame = 2
frame = 3
frame = 4
frame = 5
frame = 6
display 0x63c500, stream 0x65f9d1
Thread created
0:00:00.670419688 2092 0x638190 ERROR nvegltransform gstnvegltransform.c:286:gst_nvegl_transform_transform:<nvegltransform0> can't blit surface to EGLImage.
frame = 1
frame = 2
frame = 3
frame = 4
frame = 5
frame = 6
frame = 7
I also tried them on:
JetPack 3.3; L4T r28.2
but almost the same:
display 0x645100, stream 0x6686a1
Thread created
===== MSENC =====
VENC: VideoEncInputProcessing: 4376: VideoEncFeedImage failed. Input buffer 0 sent
VENC: NvMMLiteVideoEncDoWork: 5001: BlockSide error 0x4
Sending error event from 0BlockAvcEnc0:00:00.669944218 3124 0x7f90001950 ERROR omx gstomx.c:496:EventHandler:<video_enc> encoder got error: Bad parameter (0x80001005)
0:00:00.670008541 3124 0x63a370 ERROR omx gstomx.c:268:gst_omx_component_handle_messages:<video_enc> encoder got error: Bad parameter (0x80001005)
0:00:00.670042291 3124 0x63a370 ERROR omx gstomx.c:1285:gst_omx_port_acquire_buffer:<video_enc> Component encoder is in error state: Bad parameter
frame = 1
frame = 2
frame = 3
frame = 4
frame = 5
frame = 6
display 0x6387b0, stream 0x65b2f1
Thread created
Using winsys: x11
0:00:00.637978333 3033 0x634d90 ERROR nvegltransform gstnvegltransform.c:286:gst_nvegl_transform_transform:<nvegltransform0> can't blit surface to EGLImage.
frame = 1
frame = 2
frame = 3
frame = 4
frame = 5
frame = 6
DaneLLL
November 30, 2018, 3:39am
#5
On r28.2/TX1, r28.2.1/TX2, please follow the steps:
Modify CUDA revision in Makefile:
CUDA_PATH ?= /usr/local/cuda-9.0
Modify gstreamer pipeline:
launch_stream
<< "nveglstreamsrc name=egl_src ! "
<< "video/x-raw(memory:NVMM), <b>format=RGBA</b>, width="<< w <<", height="<< h <<", framerate=30/1 ! "
<b><< "nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! "</b>
<< "omxh264enc bitrate=2500000 name=video_enc iframeinterval=15 profile=high low-latency=false control-rate=4 ! queue ! "
<< "video/x-h264, stream-format=byte-stream ! "
<< "filesink location=test.264 ";
Replace attached libgstnveglstreamsrc.so
Follow README to build libnveglstreamproducer.so and test app
libgstnveglstreamsrc.zip (12.8 KB)
Cool DaneLLL! Thank you very much! And I also modified this code to stream an NV12 image source generated by VisionWorks, everything works correctly!
Now there is a new question. I add tee to my gst app pipeline as you said in another topic:
launch_stream
<< "video/x-raw(memory:NVMM), format=NV12, width="<< w <<", height="<< h <<", framerate=30/1 ! tee name=t "
<< "t. ! queue ! omxh264enc insert-sps-pps=true control-rate=3 ! rtph264pay ! "
<< "udpsink host=192.168.1.33 port=5000 sync=false "
<< "t. ! queue ! nvegltransform ! nveglglessink ";
Is there any extra memory copy (CPU-GPU) at tee? Thanks again.
DaneLLL
December 5, 2018, 1:32am
#7
No, there is no extra memory copy.
