Hi everyone,
I am trying to modify the pipeline in gstVideoencode example in tegra multimedia API
The modified pipeline is
“nveglstreamsrc display=(pointer_to_display) eglstream=(pointer_to_egl_stream) ! “video/x-raw(memory:NVMM), format=I420, width=1920, height=1080, framerate=30/1” ! queue ! nvvidconv ! nvoverlaysink”
The above pipeline works perfect and i am able to get the preview.
When i add extra caps between nvvidconv and nvoverlay sink as below,
“nveglstreamsrc display=(pointer_to_display) eglstream=(pointer_to_egl_stream) ! “video/x-raw(memory:NVMM), format=I420, width=1920, height=1080, framerate=30/1” ! queue ! nvvidconv ! “video/x-raw, format=I420, width=1920, height=1080, framerate=30/1” ! nvoverlaysink”
No error is shown but the pipeline doesn’t work. Is there any limitation on using nveglstreamsrc?
The code for modified pipeline which is working : -
bool initialize(EGLStreamKHR eglStream, Argus::Size2D<uint32_t> resolution,
int32_t framerate, int32_t bitrate,
const char* encoder, const char* muxer, const char* output)
// Initialize GStreamer.
gst_init(NULL, NULL);
// Create pipeline.
m_pipeline = gst_pipeline_new("video_pipeline");
if (!m_pipeline)
ORIGINATE_ERROR("Failed to create video pipeline");
// Create EGLStream video source.
GstElement *videoSource = gst_element_factory_make("nveglstreamsrc", NULL);
if (!videoSource)
ORIGINATE_ERROR("Failed to create EGLStream video source");
if (!gst_bin_add(GST_BIN(m_pipeline), videoSource))
gst_object_unref(videoSource);
ORIGINATE_ERROR("Failed to add video source to pipeline");
g_object_set(G_OBJECT(videoSource), "display", g_display.get(), NULL);
g_object_set(G_OBJECT(videoSource), "eglstream", eglStream, NULL);
GstElement *vidconv = gst_element_factory_make("nvvidconv", NULL);
if (!vidconv)
ORIGINATE_ERROR("Failed to create nvvideo converter");
if (!gst_bin_add(GST_BIN(m_pipeline), vidconv))
gst_object_unref(vidconv);
ORIGINATE_ERROR("Failed to add nvvideo converter to pipeline");
GstElement *queue1 = gst_element_factory_make("queue", NULL);
if (!queue1)
ORIGINATE_ERROR("Failed to create queue 1");
if (!gst_bin_add(GST_BIN(m_pipeline), queue1))
gst_object_unref(queue1);
ORIGINATE_ERROR("Failed to add queue 1 to pipeline");
GstElement *queue2 = gst_element_factory_make("queue", NULL);
if (!queue1)
ORIGINATE_ERROR("Failed to create queue 2");
if (!gst_bin_add(GST_BIN(m_pipeline), queue2))
gst_object_unref(queue2);
ORIGINATE_ERROR("Failed to create queue 2 to pipeline");
GstElement *overlaysink = gst_element_factory_make("nvoverlaysink", NULL);
if (!overlaysink)
ORIGINATE_ERROR("Failed to create overlay sink");
if (!gst_bin_add(GST_BIN(m_pipeline), overlaysink))
gst_object_unref(overlaysink);
ORIGINATE_ERROR("Failed to add overlay sink to pipeline");
// Create caps filter to describe EGLStream image format.
GstCaps *caps = gst_caps_new_simple("video/x-raw",
"format", G_TYPE_STRING, "I420",
"width", G_TYPE_INT, 1920,
"height", G_TYPE_INT, 1080,
"framerate", GST_TYPE_FRACTION, framerate, 1,
NULL);
if (!caps)
ORIGINATE_ERROR("Failed to create caps");
GstCapsFeatures *features = gst_caps_features_new("memory:NVMM", NULL);
if (!features)
gst_caps_unref(caps);
ORIGINATE_ERROR("Failed to create caps feature");
gst_caps_set_features(caps, 0, features);
// Link EGLStream source to queue via caps filter.
if (!gst_element_link_filtered(videoSource, queue1, caps))
ORIGINATE_ERROR("Failed to link EGLStream source to queue 1");
if (!gst_element_link(queue1, vidconv ))
ORIGINATE_ERROR("Failed to link queue 1 to video converter");
if (!gst_element_link(vidconv, overlaysink ))
ORIGINATE_ERROR("Failed to link queue 2 to overlaysink");
return true;
The code for modified pipeline which is not working(only an extra Caps is added) : -
// Create pipeline.
if (!m_pipeline)
if (!videoSource)
if (!vidconv)
if (!queue1)
if (!queue1)
if (!overlaysink)
NULL);
if (!caps)
GstCaps *caps1= gst_caps_new_simple("video/x-raw",
NULL);
if (!caps1)
ORIGINATE_ERROR("Failed to create caps 1");
if (!features)
if (!gst_element_link_filtered(vidconv, queue2, caps1))
gst_caps_unref(caps1);
ORIGINATE_ERROR("Failed to link video converter to queue2");
if (!gst_element_link(queue2, overlaysink ))
return true;
