I am trying to modify the 13_multi_camera example from the Jetson Multimedia api to replace the NVEglRenderer with a gstreamer pipeline. I have successfully run the gstVideoEncode sample and modified it to run without X11 according to: [EGL without X11](https://egl without x11) as this is also a requirement for my application.
I want to feed the m_compositedFrame into a gstreamer pipeline.
CONSUMER_PRINT("Render frame %d\n", g_frame_count - m_framesRemaining);
if (m_streams.size() > 1)
/* Composite multiple input to one frame */
NvBufferComposite(m_dmabufs, m_compositedFrame, &m_compositeParam);
g_renderer->render(m_compositedFrame);
else
g_renderer->render(m_dmabufs[0]);
I have also tried modifying simpleEGLStreams_producer to work for my application but have had no success so far.
Any push in the right direction would be appreciated as MMAPI is still quite new to me, I am far more familiar with the accelerated gstreamer on jetson for video pipelines.
Thank you.
