• Hardware Platform (Jetson / GPU): Both Jetson and dGPU
• DeepStream Version: 6.0.1 and 6.1.1
• JetPack Version (valid for Jetson only): 4.6
• TensorRT Version: 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only): 515.76
• Issue Type( questions, new requirements, bugs): Question
Hi All,
Currently, I’m trying to extend or add margin to the cropped area created by the detection model which is PGIE. My pipeline looks like below:
[DECODING] → nvstreammux → nvinfer [PGIE] → nvtracker → nvinfer [SGIE] → nvvideoconvert → capsfilter → fakesink
As far as I know, DeepStream feeds the area detected area by the PGIE to one or multiple SGIEs for classification. However, I think that my classification models require a little more extended area than what the PGIE currently detects since they are producing the same classification output for every detection. My sample scenario involves detecting faces and feeding these areas to the age and gender classification models.
To solve this, I have implemented a callback (probe) function and did the following:
- Attached callback function to src pad of the PGIE (nvinfer) element
- Attached callback function to sink pad of the Tracker (nvtracker) element
- Attached callback function to sink pad of the SGIE (nvinfer) element
My callback function looks like the following:
def nvinfer_src_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
rect_params = obj_meta.rect_params
# rect_params.left = int(rect_params.left - 20)
# rect_params.top = int(rect_params.top - 20)
# rect_params.width = int(rect_params.width + 40)
# rect_params.height = int(rect_params.height + 40)
return Gst.PadProbeReturn.OK
And the callback function call made as follows:
pgie_src_pad = pgie.get_static_pad("src")
if not pgie_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, nvinfer_src_pad_buffer_probe, 0)
Once I implement the whole idea like this, the code gets stuck at try-catch blocks. Is there any other possible way to manipulate detection areas of the PGIE before feeding them into SGIEs?
