ADD custom object Meta to Frame Meta in PGIE src pad, but SGIE not working on my custom obj meta
• Hardware Platform (Jetson / GPU) : JETSON NANO
• DeepStream Version : 6.0.0
• JetPack Version (valid for Jetson only) : 4.6
• TensorRT Version : 8.0
  • hello , I’m trying to add new object to frame meta in deepstream .
  • i want to add my custom Bbox object meta to frame meta and want to my Secondary gie makes predictions about my custom Bbox object meta. using function **nvds_add_object_meta_to_frame() ** works well, but my secondary gie doesn’t inference on my custom Bbox object meta.
  • add custom Bbox object meta on PGIE SRC PAD but my SGIE didn’t work. is there any correct way to add custom Bbox object meta to FRAME META ??
my pipeline is like below …
cam → …→ pgie1 → (here i add new object with probe1) → tracker → sgie1 → nvosd → overlaysink
THANKS !
Suppose it should work as pgie also do same thing as you.
@GURUGURU @kesong
Check my previous thread where this case is solved: Secondary GIE with custom bounding boxes - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
/M
@MathiasDall @kesong
Thanks for the reply. i set <detector_bbox_info> then push to the PGIE src pad, but according to your answer, i have to set OSD<rect_params> for the SGIE. did i understand right ?
