Custom input of SGIE
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• Issue Type( questions, new requirements, bugs) questions
In my Python application, the current pipeline is structured as streammux → pgie (person detection) → sgie (object detection), where sgie operates on the bounding boxes provided by pgie. However, I would like sgie to receive expanded bounding boxes (i.e., enlarging pgie’s output to include more context). What is the solution for this, and could you provide an example?
  1. why do you need to expand the bboxes? how much do you need to expand the bboxes?
  2. you can loop all object_meta generated by pgie, then modify the bbox rectangle coordinates. please refer to deepstream-test1 for how to loop object meta and deepstream-infer-tensor-meta-test for how to modify the bbox rectangle coordinates.
Thanks in advance. My solution is to write a custom gst-nvinfer with some custom configurations that can expand the primary GIE output bounding box before feeding it to the secondary GIE.
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
