How to fix Orin NX's CUDA Performance
I’m running a simulation of a drone recording frames of its ground and want to see SURF able to find matches on Jetson Orin NX
My setup:
Jetpack 6.0
Ubuntu 22.04LTS
L4T 36.3.0
CUDA Arch 8.7
CUDA 12.2.140
OpenCV 4.10.0 with CUDA: YES
Python 3.10.12
I ran the test on my original computer that has the GPU of NVIDIA GeForce MX330 with the performance that averages 28ms on each frame of the video
compare that to the Jetson’s performance 45ms per frame. I tried many things in code to make it work. However the function of OpenCV surf.detectWithDescriptors() will always result in ~45ms in processing
Is there a way to enable the Jetson to be able to perform the SURF detect and compute of 1280x720 images in sub 30ms?
Here is the code that I run as a reference:
import cv2
import time
import numpy as np
import matplotlib.pyplot as plt
from collections import deque
class SURFProcessor:
    def __init__(self, min_matches=10, fps=50):
        self.surf = cv2.cuda.SURF_CUDA_create(
            _hessianThreshold=500,
            _nOctaves=1,
            _nOctaveLayers=1,
            _extended=False,
            _upright=True,
        self.matcher = cv2.cuda.DescriptorMatcher_createBFMatcher(cv2.NORM_L2)
        self.stream = cv2.cuda.Stream()
        self.min_matches = min_matches
        self.GPU_image = cv2.cuda_GpuMat(720, 1280, cv2.CV_8UC1)
        self.current_GPU_descriptors = cv2.cuda_GpuMat()
        self.previous_GPU_descriptors = cv2.cuda_GpuMat()
        self.prev_gray = cv2.cuda.registerPageLocked(np.zeros((720, 1280), dtype=np.uint8))
        self.prev_keypoints = None
        self.prev_frame = None
        self.fps = fps
    def process_frame(self, current_frame):
        if current_frame is None:
            return
        current_gray = cv2.cvtColor(current_frame, cv2.COLOR_BGR2GRAY)
        self.GPU_image.upload(current_gray, stream=self.stream)
        current_gpu_keypoints, self.current_GPU_descriptors = self.surf.detectWithDescriptors(
            self.GPU_image,
            None,
        current_keypoints = self.surf.downloadKeypoints(current_gpu_keypoints)
        if (current_keypoints is not None and
            self.prev_keypoints is not None and
            len(current_keypoints) > 0):
            matches = self.matcher.match(
                self.current_GPU_descriptors,
        # Update previous frame data
        self.previous_GPU_descriptors = self.current_GPU_descriptors.clone()
        self.prev_keypoints = current_keypoints
        self.stream.waitForCompletion()
def main():
    if cv2.cuda.getCudaEnabledDeviceCount() == 0:
        print("CUDA is not available. Exiting...")
        return
    cap = cv2.VideoCapture('some_drone_video.avi')
    if not cap.isOpened():
        print("Error: Could not open video capture")
        return
    fps = int(cap.get(cv2.CAP_PROP_FPS))
    fourcc = cv2.VideoWriter_fourcc(*'XVID')
    out = cv2.VideoWriter('matched_frames4.avi',
                        fourcc,
                        fps,
                        (2560, 720))
    processor = SURFProcessor(min_matches=10, fps=fps)
    processing_times = []
    frame_count = 0
    while True:
        ret, frame = cap.read()
        if not ret:
            break
        t1 = time.time()
        processor.process_frame(frame)
        t2 = time.time()
        processing_time = t2 - t1
        processing_times.append(processing_time)
        print(f"Frame {frame_count + 1} processing time: {processing_time:.4f} seconds")
        frame_count += 1
    avg_time = np.mean(processing_times) * 1000
    std_time = np.std(processing_times) * 1000
    max_time = np.max(processing_times) * 1000
    min_time = np.min(processing_times) * 1000
    cap.release()
    print("\nPerformance Statistics:")
    print(f"Average processing time: {avg_time:.1f}ms")
    print(f"Standard deviation: {std_time:.1f}ms")
    print(f"Maximum processing time: {max_time:.1f}ms")
    print(f"Minimum processing time: {min_time:.1f}ms")
    print(f"Frames per second: {1/np.mean(processing_times):.2f}")
if __name__ == "__main__":
    main()
Does the SURF function use GPU for computation?
Please try to verify this via monitoring the system with tegrastats:
$ sudo tegrastats
You can maximize the device performance with the following command:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Please try if this can reduce the latency of SURF.
Hey, AastaLLL
Thank you for responding,
From my understanding Jetson uses GPU whenever I run the SURF algorithm as when I run jtop and watch over the GPU tab it does show that it uses GPU. as well as sudo tegrastats.
But I noticed that its not 100% usage of all time just in certain time peroids it uses 100% then drops to either 33% or around 70%, maybe its normal?
I have used the sudo nvmodel -m 0 as well and it still didn’t enhance the performance, still gives me 45ms performance
Here is rough screen shot of jtop of the GPU tab graph
The usage depends on the OpenCV implementation.
A common reason is that the GPU might need to wait for the input data to execute.
So sometimes the resources are idle. (indicating memory read/write > SURF computation).
Usually, this can be improved by moving the pipeline components to GPU as much as possible.
For example, cv2.cvtColor(current_frame, cv2.COLOR_BGR2GRAY) looks like a CPU call.
Please also try to run the jetson_clocks to fix the clocks to the maximum.
