the script is recommended in post: [How do I install openCV with CUDA support? - Jetson & Embedded Systems / Jetson Orin Nano - NVIDIA Developer Forums](How do I install openCV with CUDA support?
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
I exec the following cmds to set agx orin to maximum performance mode
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
now the cuda surf detector process a 800x800 image, it takes ~20ms to find 513 key-points.
the agx orin 32GB is about 5 times slower than Jetson Xavier。
