Dear Guys,
I’m using JetPack 3.3 (./JetPack-L4T-3.3-linux-x64_b39.run),
I have tried several times this command, but when I booted the device, DTB haven’t updated.
sudo ./flash.sh -r -k DTB jetson-tx1 mmcblk0p1
Only flash all the dtb is updated:
sudo ./flash.sh jetson-tx1 mmcblk0p1
Flash log as bellowed:
# L4T BSP Information:
# R28 (release), REVISION: 2.0, GCID: 10567845, BOARD: t210ref, EABI: aarch64,
# DATE: Fri Mar 2 04:58:16 UTC 2018
# Target Board Information:
# Name: jetson-tx1, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
copying bctfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/BCT/P2180_A00_LP4_DSC_204Mhz.cfg)... done.
copying bootloader(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/dennis/nvidia/64_TX1/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb to rootfs... done.
done.
Making Boot image... done.
copying bcffile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p2597-devkit.xml)... done.
Existing sosfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
Existing bpffile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying wb0boot(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)... done.
Reusing existing system.img...
done.
Existing tbcfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)... done.
copying cfgfile(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/cfg/gnu_linux_tegraboot_emmc_full.xml) to flash.xml... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
device size -------------- 31276924928
bootpart size ------------ 8388608
userpart size ------------ 31268536320
Erase Block Size --------- 2097152
sector size -------------- 4096
Partition Config file ---- flash.xml
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(24 partitions) ***
[ BCT] BH 0 8191 4.0MiB
[ NVC] BH 8192 16383 4.0MiB nvtboot.bin
[ PPT] UH 0 4095 2.0MiB
[ GP1] UH 4096 8191 2.0MiB
[ APP] UH 8192 29368319 14336.0MiB system.img
[ TBC] UV 29368320 29372415 2.0MiB nvtboot_cpu.bin
[ EBT] UV 29372416 29380607 4.0MiB cboot.bin
[ BPF] UV 29380608 29384703 2.0MiB bpmp.bin
[ WB0] UV 29384704 29396991 6.0MiB warmboot.bin
[ RP1] UV 29396992 29405183 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ TOS] UV 29405184 29417471 6.0MiB tos.img
[ EKS] UV 29417472 29421567 2.0MiB eks.img
[ FX] UV 29421568 29425663 2.0MiB
[ BMP] UV 29425664 29687807 128.0MiB bmp.blob
[ SOS] UV 29687808 29728767 20.0MiB
[ EXI] UV 29728768 29859839 64.0MiB
[ LNX] UV 29859840 29990911 64.0MiB boot.img
[ DTB] UV 29990912 29999103 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ NXT] UV 29999104 30003199 2.0MiB
[ MXB] UV 30003200 30015487 6.0MiB
[ MXP] UV 30015488 30027775 6.0MiB
[ USP] UV 30027776 30031871 2.0MiB
[ UDA] UV 30031872 61067263 15154.0MiB
[ GPT] UH 61067264 61071359 2.0MiB
copying flasher(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [DTB] with tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb ***
./tegraflash.py --bl cboot.bin --bldtb tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb --chip 0x21 --applet nvtboot_recovery.bin --cfg flash.xml --bct P2180_A00_LP4_DSC_204Mhz.cfg --bct P2180_A00_LP4_DSC_204Mhz.cfg --cfg flash.xml --cmd "sign; write DTB ./signed/tegra210-jetson-tx1-p2597-2180-a01-devkit_sigheader.dtb.encrypt; reboot" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0091 ] Generating RCM messages
[ 0.0110 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0125 ] RCM 0 is saved as rcm_0.rcm
[ 0.0135 ] RCM 1 is saved as rcm_1.rcm
[ 0.0135 ] List of rcm files are saved in rcm_list.xml
[ 0.0135 ]
[ 0.0135 ] Signing RCM messages
[ 0.0153 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0168 ] Assuming zero filled SBK key
[ 0.0293 ]
[ 0.0293 ] Copying signature to RCM mesages
[ 0.0307 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.0327 ]
[ 0.0327 ] Parsing partition layout
[ 0.0340 ] tegraparser --pt flash.xml.tmp
[ 0.0357 ]
[ 0.0358 ] Creating list of images to be signed
[ 0.0370 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0437 ]
[ 0.0438 ] Generating signatures
[ 0.0457 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0474 ] Assuming zero filled SBK key
[ 0.1427 ]
[ 0.1428 ] Generating br-bct
[ 0.1452 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.1471 ] Copying Sdram info from 1 to 2 set
[ 0.1539 ] Copying Sdram info from 2 to 3 set
[ 0.1539 ]
[ 0.1540 ] Updating boot device parameters
[ 0.1558 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 0.1573 ] Warning: No sdram params
[ 0.1578 ]
[ 0.1578 ] Updating bl info
[ 0.1596 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1622 ]
[ 0.1622 ] Updating secondary storage information into bct
[ 0.1638 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.1656 ]
[ 0.1656 ] Get Signed section bct
[ 0.1671 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.1686 ]
[ 0.1687 ] Signing BCT
[ 0.1713 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1727 ] Assuming zero filled SBK key
[ 0.1737 ]
[ 0.1737 ] Updating BCT with signature
[ 0.1750 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.1767 ]
[ 0.1767 ] Copying signatures
[ 0.1779 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1791 ] Run tegrabct to update tboot signature in bct
[ 0.1860 ]
[ 0.1860 ] Copying signed file in /home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/signed
[ 0.2068 ] Generating RCM messages
[ 0.2084 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.2101 ] RCM 0 is saved as rcm_0.rcm
[ 0.2111 ] RCM 1 is saved as rcm_1.rcm
[ 0.2113 ] List of rcm files are saved in rcm_list.xml
[ 0.2113 ]
[ 0.2114 ] Signing RCM messages
[ 0.2131 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.2147 ] Assuming zero filled SBK key
[ 0.2280 ]
[ 0.2280 ] Copying signature to RCM mesages
[ 0.2295 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.2314 ]
[ 0.2315 ] Boot Rom communication
[ 0.2332 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml --skipuid
[ 0.2348 ] RCM version 0X210001
[ 0.2841 ] Boot Rom communication completed
[ 1.2942 ]
[ 1.2942 ] Parsing partition layout
[ 1.2964 ] tegraparser --pt flash.xml.tmp
[ 1.2993 ]
[ 1.2993 ] Creating list of images to be signed
[ 1.3014 ] tegrahost --chip 0x21 --partitionlayout flash.xml.bin --list images_list.xml
[ 1.3095 ]
[ 1.3095 ] Generating signatures
[ 1.3115 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.3131 ] Assuming zero filled SBK key
[ 1.4109 ]
[ 1.4109 ] Send BCT from Host
[ 1.4109 ] Generating br-bct
[ 1.4126 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 1.4138 ] Copying Sdram info from 1 to 2 set
[ 1.4174 ] Copying Sdram info from 2 to 3 set
[ 1.4174 ]
[ 1.4174 ] Updating boot device parameters
[ 1.4188 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.xml.bin
[ 1.4203 ] Warning: No sdram params
[ 1.4207 ]
[ 1.4207 ] Updating bl info
[ 1.4221 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.4251 ]
[ 1.4251 ] Updating secondary storage information into bct
[ 1.4266 ] tegraparser --pt flash.xml.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 1.4284 ]
[ 1.4284 ] Get Signed section bct
[ 1.4299 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 1.4316 ]
[ 1.4316 ] Signing BCT
[ 1.4344 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 1.4358 ] Assuming zero filled SBK key
[ 1.4370 ]
[ 1.4370 ] Updating BCT with signature
[ 1.4385 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 1.4400 ]
[ 1.4401 ] Sending BCTs
[ 1.4414 ] tegrarcm --download bct P2180_A00_LP4_DSC_204Mhz.bct
[ 1.4426 ] Applet version 00.01.0000
[ 1.4472 ] Sending bct
[ 1.4474 ] [................................................] 100%
[ 1.5707 ]
[ 1.5707 ] Sending bootloader and pre-requisite binaries
[ 1.5726 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb 0
[ 1.5746 ] Applet version 00.01.0000
[ 1.5797 ] Sending ebt
[ 1.5802 ] [................................................] 100%
[ 1.6789 ] Sending rp1
[ 1.6803 ] [................................................] 100%
[ 1.7828 ]
[ 1.7829 ]
[ 1.7850 ] tegrarcm --boot recovery
[ 1.7869 ] Applet version 00.01.0000
[ 1.7944 ]
[ 1.7944 ] Writing partition
[ 1.7960 ] tegradevflash --write DTB /home/dennis/nvidia/64_TX1/Linux_for_Tegra/bootloader/signed/tegra210-jetson-tx1-p2597-2180-a01-devkit_sigheader.dtb.encrypt
[ 1.7974 ] Cboot version 00.01.0000
[ 2.4421 ] Nothing to write
[ 2.4421 ]
[ 2.4422 ] Coldbooting the device
[ 2.4444 ] tegradevflash --reboot coldboot
[ 2.4463 ] Cboot version 00.01.0000
[ 2.4520 ]
*** The [DTB] has been updated successfully. ***
