Hello everyone,
I’m trying to lock the GPU clocks on my ZOTAC RTX 5090 AMP, which is running in a headless Linux server, but I’m having trouble.
My Goal: I need to force the SM (Streaming Multiprocessor) clock and the memory clock to specific, fixed frequencies for a compute-intensive workload to get consistent performance.
System Details:
GPU: ZOTAC RTX 5090 AMP
OS: Ubuntu 24.04
NVIDIA Driver Version: 580.95.05
Setup: This is a headless server with no X server running.
What I’ve Tried: I attempted to use nvidia-smi to set the application clock limits. I tried using:
nvidia-smi -lgc [target_sm_clock] and nvidia-smi -lmc [target_memory_clock]
However, these commands failed or did not lock the clocks as expected. The GPU still seems to be managing its power states and frequencies automatically. I’ve also ensured that nvidia-persistenced is running.
My Question: Is there a different or more effective method to force the GPU to use a specific SM frequency and memory frequency on a headless system?
For example, are there nvidia-settings commands that work without an X server, or any specific kernel module parameters I need to set?
Any help or guidance would be greatly appreciated.
Thank you!
