• Hardware Platform (Jetson / GPU) : Jetson AGX Orin • DeepStream Version : 7.0 • JetPack Version (valid for Jetson only): 6.0 • TensorRT Version : with deep stream 7.0 docker image (8.6.2.3-1+cuda12.2) • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
Can you give an example of getting image from VideoBuffer?
Get ideas from here: link
Here is my implemented code but not working.
VideoBuffer video_buffer = buffer;
auto width = video_buffer.width();
auto height = video_buffer.height();
auto format = video_buffer.format();
std::cout << "Video Buffer: " << " Width = " << width
<< " Height = " << height << " Format = " << format
<< std::endl;
video_buffer.read([&](const void* data, size_t size) -> size_t {
const unsigned char* p_byte = (const unsigned char*) data;
for (auto p = p_byte; p < p_byte + size; p++) {
// take a peek on the data
cv::Mat yuv_image(height + height / 2, width, CV_8UC1, (void*)p_byte);
cv::Mat rgb_image;
cv::cvtColor(yuv_image, rgb_image, cv::COLOR_YUV2RGB_I420);
cv::imwrite("output_image.jpg", rgb_image);
return size;
Please let me know if you have any hints on how to solve this issue.
Thanks in advance
All tests in /opt/nvidia/deepstream/deepstream-7.0/service-maker/sources/apps do not have any examples related to VideoBuffer.
I only found a small example at: Service Maker for C/C++ Developers — DeepStream documentation
Base on link. I’m pretty sure my code doesn’t work because I don’t know how to handle p_byte
Here is my full C++ code
#include <gst/gstbuffer.h>
#include <spdlog/spdlog.h>
#include <cstdlib>
#include <iostream>
#include <opencv2/core/mat.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/opencv.hpp>
#include <string>
#include "pipeline.hpp"
using namespace deepstream;
#define PGIE_CLASS_ID_HEAD 1
#define PGIE_CLASS_ID_PERSON 0
class SampleBufferObserver : public BufferProbe::IBufferOperator {
public:
virtual probeReturn handleBuffer(BufferProbe &probe, Buffer &buffer) {
// std::cout << "Video Buffer: " << " Width = " << width
// << " Height = " << height << " Format = " << format
// << std::endl;
cv::Mat rgb_image;
return size;
BatchMetadata batch_meta = video_buffer.getBatchMetadata();
batch_meta.iterate([](const FrameMetadata &frame_data) {
auto head_count = 0;
auto person_count = 0;
auto batch_id = frame_data.padIndex();
auto frame_num = frame_data.frameNum();
frame_data.iterate([&](const ObjectMetadata &object_data) {
auto class_id = object_data.classId();
if (class_id == PGIE_CLASS_ID_HEAD) {
head_count++;
} else if (class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
// auto local_id = object_data.objectId();
// auto conf = object_data.confidence();
// spdlog::info("Local ID : {}", local_id);
// spdlog::info("Conf : {}", conf);
// std::cout << "Object Counter: " << " Pad Idx = "
// << frame_data.padIndex()
// << " Frame Number = " << frame_data.frameNum()
// << " Head Count = " << head_count
// << " Person Count = " << person_count << std::endl;
return probeReturn::Probe_Ok;
int main(int argc, char *argv[]) {
// export
// NVDS_MODULE_PATH="/opt/nvidia/deepstream/deepstream/service-maker/sources/modules"
if (argc < 2) {
std::cout << "Usage: " << argv[0] << " <YAML config file>" << std::endl;
return 0;
std::string file = argv[1];
std::string suffix = "yml";
spdlog::info(" Pipeline running on File: {}", file);
if (std::equal(suffix.rbegin(), suffix.rend(), file.rbegin())) {
try {
Pipeline pipeline("Test pipeline", file);
pipeline
.attach("capsfilter",
new BufferProbe("counter", new SampleBufferObserver))
.attach("tracker", "measure_fps_probe", "measure_fps", "src")
.start()
.wait();
} catch (const std::exception &e) {
std::cerr << e.what() << std::endl;
return -1;
return 0;
Currently there is no ready-made code. please refer to C++ version sample opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-image-meta-test\deepstream_image_meta_test.c. nvds_obj_enc_process is used to save frame.
