I connected my camera module to TK1 Board and I used tegra terminal for i2cdetect camera
if I use EEPROM camera module detected slave id but not detecting ImageSensor slave id.
How to get Image Sensor Slave ID?
thanks to read
thanks to read
The sensor slave id can be found from the module spec.
Or you can scan all the addresses in the i2c bus you used
Camera module needs a clock source, to launch i2c-bus and camera kernel. So I assembled simple clock generator on 24MHz, and I could see camera address on i2c-bus.
For generating a clock you need modify the driver, and Tegra shot generates clock itself.
Link on generator scheme
[url]Using CMOS Schmitt trigger inverters in quartz crystal oscillator circuit - Electrical Engineering Stack Exchange
