I’ve been developing a 2 stage lincence-plate-recognizer on deepstream, by modifying deepstream-test2 application.
I’m trying to get the number plate characters in order from left to right.
I was able to do this if there is only one plate detected in the frame.
However, I’m not sure how to approach the problem of getting the different characters, based on what their parent is.
Is there a parent id that i can get from each child, and then add them to different arrays based on their parent. Is the parent id a simple int or char, or is it guint?
If you could give me some sort of direction or example as to how to aproach this, I would appreciate it.
Kind regards.
