How to get roi-rf coordinates from Nvdsanalytics
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 5.0.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 440.118
I want to check if an object is within ROI-RF coordinates or not.
Is there a way to get the ROI-RF coordinate from the nvdsanalytics config-file
deepstream-occupancy-analytics
you can refer to this sample app
The given link does not help. I need to get the coordinates of the ROI-RF or a means to know that the object-id is in the ROI.
In the example it just gives the meta-data on a frame level not per object something like what can be achieved for Direction.
yes, this sample not use ROI, but it can teach you how use
NVDS_USER_OBJ_META_NVDSANALYTICS
you can try with:
for (NvDsMetaList *l_user_meta = obj_meta->obj_user_meta_list; l_user_meta != NULL;
                        l_user_meta = l_user_meta->next) {
                    NvDsUserMeta *user_meta = (NvDsUserMeta *) (l_user_meta->data);
                    if(user_meta->base_meta.meta_type == NVDS_USER_OBJ_META_NVDSANALYTICS)
                        NvDsAnalyticsObjInfo * user_meta_data = (NvDsAnalyticsObjInfo *)user_meta->user_meta_data;
                        if (user_meta_data->dirStatus.length()){
                            g_print ("object %lu moving in %s\n", obj_meta->object_id, user_meta_data->dirStatus.c_str());
This one gives the dirStatus which is already evident from the nvdsanalytics example.
I am interested in finding out if a particular object is with the ROI-RF as defined in the config file.
Is there a mechanism to get access to the ROI-RF coordinates as defined in the config file. I can write a custom logic to find if a point is with ROI… I just need the coordinates.
