Now I am using Tesla L4 card for both video decoding and inference.
As I know, they use different parts of the card, so I want to get the usage of them seperately.
Besides, I know there are four decoder units of Tesla L4 card, and can I get each usage of them?
Thanks a lot! Looks it is the solution!
Besides, do you know how to monitor the tensor cores usage only?
Because I want to monitor the usage of video stream decoding and model inference seperately
Hi @kungedefaxing, you can select the options that you want listed here:
❯ nvidia-smi dmon -h
GPU statistics are displayed in scrolling format with one line
per sampling interval. Metrics to be monitored can be adjusted
based on the width of terminal window. Monitoring is limited to
a maximum of 16 devices. If no devices are specified, then up to
first 16 supported devices under natural enumeration (starting
with GPU index 0) are used for monitoring purpose.
It is supported on Tesla, GRID, Quadro and limited GeForce products
for Kepler or newer GPUs under x64 and ppc64 bare metal Linux.
Note: On MIG-enabled GPUs, querying the utilization of encoder,
decoder, jpeg, ofa, gpu, and memory is not currently supported.
Usage: nvidia-smi dmon [options]
Options include:
[-i | --id]: Comma separated Enumeration index, PCI bus ID or UUID
[-d | --delay]: Collection delay/interval in seconds [default=1sec]
[-c | --count]: Collect specified number of samples and exit
[-s | --select]: One or more metrics [default=puc]
Can be any of the following:
p - Power Usage and Temperature
u - Utilization
c - Proc and Mem Clocks
v - Power and Thermal Violations
m - FB, Bar1 and CC Protected Memory
e - ECC Errors and PCIe Replay errors
t - PCIe Rx and Tx Throughput
[N/A | --gpm-metrics]: Comma-separated list of GPM metrics (no space in between) to watch
Available metrics:
Graphics Activity = 1
SM Activity = 2
SM Occupancy = 3
Integer Activity = 4
Tensor Activity = 5
DFMA Tensor Activity = 6
HMMA Tensor Activity = 7
IMMA Tensor Activity = 9
DRAM Activity = 10
FP64 Activity = 11
FP32 Activity = 12
FP16 Activity = 13
PCIe TX = 20
PCIe RX = 21
NVDEC 0-7 Activity = 30-37
NVJPG 0-7 Activity = 40-47
NVOFA 0 Activity = 50
NVLink Total RX = 60
NVLink Total TX = 61
NVLink L0-17 RX = 62,64,66,...,96
NVLink L0-17 TX = 63,65,67,...,97
[N/A | --gpm-options]: options of which level of GPM metrics to monitor:
d - Display Device level GPM Metrics only
m - Display MIG level GPM Metrics only
dm - Display both Device and MIG level GPM Metrics only
md - Display both Device and MIG level GPM Metrics only
[-o | --options]: One or more from the following:
D - Include Date (YYYYMMDD) in scrolling output
T - Include Time (HH:MM:SS) in scrolling output
[-f | --filename]: Log to a specified file, rather than to stdout
[-h | --help]: Display help information
[N/A | --format]: Output format specifiers:
csv - Format dmon output as a CSV
nounit - Remove units line from dmon output
noheader - Remove heading line from dmon output
I have a question regarding decoder unit utilization on my RTX 5060 Ti GPU.
I have two decoder units in use, and by running the command you previously provided, I can monitor the usage of different decoder units. However, I noticed something unusual: while Decoder Unit 0 consistently shows 100% utilization, Decoder Units 1 through 7 always report 0% usage, even when decoding workloads are active.
Could you help explain why this imbalance occurs? Is this expected behavior, or could it indicate a configuration issue?
Hi @kungedefaxing, although you can have multiple decoder sessions open in parallel (software), the NVIDIA RTX 5060 Ti GPU only has one NVDEC (hardware). NVIDIA L4 GPU, on the other hand, has four NVDECs. The command line I provided shows the hardware utilization. That is why it only shows one being used for the 5060 Ti. No matter how many decoder sessions you open, they will share the same NVDEC in this case.
