How to get vulkan working on a ubuntu20.04 docker container
hello,
Can anyone point me in the right direction on how I would run a Vulkan application inside a docker container?
I am using nvidia/cuda:11.6.–base-ubuntu20.04 as base image but I am not able to get Vulkan working, I got the following error:
vulkan@dolores:/# vulkaninfo
thanks in advance,
you need install libvulkan-dev
if you are running it inside a docker container, then you need to connect your docker instance to a X11 server in you host and forward your display to docker
docker run -e DISPLAY=localhost:0
you need to install X11 server software, like XMing X server or Cygwin/X or VcXsrv or XQuartz
and make sure that X11 server is running and working
