Hi.
Would you please tell me how to handle the specific PCIe MSI vector?
The following code returns 1 to indicate the number of MSI vectors is just one.
err = pci_enable_msi_range(pdev, 1, SAP_NUM_MSI_VECTORS_REQUEST);
However, the driver code (kernel-4.4/drivers/pci/host/pci-tegra.c) seems to check the all 256 (= 8 * 32) MSI vectors. Is there any Tegra specific API function to know the MSI vector triggered?
static irqreturn_t tegra_pcie_msi_irq(int irq, void *data)
struct tegra_pcie *pcie = data;
struct tegra_msi *msi = &pcie->msi;
unsigned int i, processed = 0;
PR_FUNC_LINE;
for (i = 0; i < 8; i++) {
unsigned long reg = afi_readl(pcie, AFI_MSI_VEC0_0 + i * 4);
while (reg) {
unsigned int offset = find_first_bit(®, 32);
unsigned int index = i * 32 + offset;
unsigned int irq_num;
/* check if there are any interrupts in this reg */
if (offset == 32)
break;
/* clear the interrupt */
afi_writel(pcie, 1 << offset, AFI_MSI_VEC0_0 + i * 4);
irq_num = irq_find_mapping(msi->domain, index);
if (irq_num) {
if (test_bit(index, msi->used))
generic_handle_irq(irq_num);
else
dev_info(pcie->dev, "unhandled MSI\n");
} else {
* that's weird who triggered this?
* just clear it
dev_info(pcie->dev, "unexpected MSI\n");
/* see if there's any more pending in this vector */
processed++;
return processed > 0 ? IRQ_HANDLED : IRQ_NONE;
