How to improve the performance of using CUDA IPC shared memory?
Process A transfer data to process B by cuda shared memory in my project .
A: malloc 25Mib data by 0.000602s ,copy memory from host to device by 0.007211s.
B: copy shared memory to managed device’s memory using 0.063s
why process B copy data so slow ? any suggestions to speed it up ?
OS: CENTOS8.2 ,device: RTX A4000
managed memory might be page-faulting as you copy to it. If so, prefetch it to the device, first.
you might get better help by showing a complete code
thanks Robert,
Process A:
err=cudaMalloc(pdev,pdiq->proc.datalen);
cudaMemcpy(*pdev,fibiq,pdiq->proc.datalen, cudaMemcpyHostToDevice);
cudaIpcGetMemHandle(&mhandle,*pdev);
send handle to B
Process B
cudaIpcOpenMemHandle(&pdev,*pmh,cudaIpcMemLazyEnablePeerAccess);
cudaMemcpy(rawiq,pdev,len,cudaMemcpyDeviceToDevice);
I tried cudaMemPrefetchAsync ,but nothing hanppe.
because cudaMemPrefetchAsync work only on memory by managed mallocated ?
sorry, I wouldn’t be able to help further without a complete code. What I posted before was just a guess based on a small amount of information. I don’t really know if you are using managed memory or not. It might be completely irrelevant to whatever you are experiencing. When I refer to a “complete” code, I don’t usually mean “your whole code”. The goal is to provide something that shows just the steps you have outlined here, but can be copy, pasted, and compiled and run, without having to add anything or change anything, and see the issue.
This is a such a common request across many forums that you can find whole web pages dedicated to explaining the idea. 1 2
I modified the simpleIPC sample code as follows, to create an extra buffer in the child process, then copy 64MB from the IPC buffer to the extra buffer, and ran it on a GTX1660 Super GPU:
$ cat simpleIPC.cu
/* Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 *  * Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *  * Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 *  * Neither the name of NVIDIA CORPORATION nor the names of its
 *    contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
 * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
 * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
 * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * This sample demonstrates Inter Process Communication
 * using one process per GPU for computation.
#include <stdio.h>
#include <stdlib.h>
#include <vector>
#include "helper_cuda.h"
#include "helper_multiprocess.h"
#include <time.h>
#include <sys/time.h>
#include <iostream>
#define USECPSEC 1000000ULL
unsigned long long dtime_usec(unsigned long long start){
  timeval tv;
  gettimeofday(&tv, 0);
  return ((tv.tv_sec*USECPSEC)+tv.tv_usec)-start;
static const char shmName[] = "simpleIPCshm";
// For direct NVLINK and PCI-E peers, at max 8 simultaneous peers are allowed
// For NVSWITCH connected peers like DGX-2, simultaneous peers are not limited
// in the same way.
#define MAX_DEVICES (32)
#define DATA_SIZE (64ULL << 20ULL)  // 64MB
#if defined(__linux__)
#define cpu_atomic_add32(a, x) __sync_add_and_fetch(a, x)
#elif defined(WIN32) || defined(_WIN32) || defined(WIN64) || defined(_WIN64)
#define cpu_atomic_add32(a, x) InterlockedAdd((volatile LONG *)a, x)
#else
#error Unsupported system
#endif
typedef struct shmStruct_st {
  size_t nprocesses;
  int barrier;
  int sense;
  int devices[MAX_DEVICES];
  cudaIpcMemHandle_t memHandle[MAX_DEVICES];
  cudaIpcEventHandle_t eventHandle[MAX_DEVICES];
} shmStruct;
__global__ void simpleKernel(char *ptr, int sz, char val) {
  int idx = blockIdx.x * blockDim.x + threadIdx.x;
  for (; idx < sz; idx += (gridDim.x * blockDim.x)) {
    ptr[idx] = val;
static void barrierWait(volatile int *barrier, volatile int *sense,
                        unsigned int n) {
  int count;
  // Check-in
  count = cpu_atomic_add32(barrier, 1);
  if (count == n)  // Last one in
    *sense = 1;
  while (!*sense)
  // Check-out
  count = cpu_atomic_add32(barrier, -1);
  if (count == 0)  // Last one out
    *sense = 0;
  while (*sense)
static void childProcess(int id) {
  volatile shmStruct *shm = NULL;
  cudaStream_t stream;
  sharedMemoryInfo info;
  size_t procCount, i;
  int blocks = 0;
  int threads = 128;
  cudaDeviceProp prop;
  std::vector<void *> ptrs;
  std::vector<cudaEvent_t> events;
  std::vector<char> verification_buffer(DATA_SIZE);
  if (sharedMemoryOpen(shmName, sizeof(shmStruct), &info) != 0) {
    printf("Failed to create shared memory slab\n");
    exit(EXIT_FAILURE);
  shm = (volatile shmStruct *)info.addr;
  procCount = shm->nprocesses;
  printf("Process %d: Starting on device %d...\n", id, shm->devices[id]);
  checkCudaErrors(cudaSetDevice(shm->devices[id]));
  checkCudaErrors(cudaGetDeviceProperties(&prop, shm->devices[id]));
  checkCudaErrors(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
  checkCudaErrors(cudaOccupancyMaxActiveBlocksPerMultiprocessor(
      &blocks, simpleKernel, threads, 0));
  blocks *= prop.multiProcessorCount;
  // Open and track all the allocations and events created in the master
  // process for use later
  for (i = 0; i < procCount; i++) {
    void *ptr = NULL;
    cudaEvent_t event;
    // Notice, we don't need to explicitly enable peer access for
    // allocations on other devices.
    checkCudaErrors(
        cudaIpcOpenMemHandle(&ptr, *(cudaIpcMemHandle_t *)&shm->memHandle[i],
                             cudaIpcMemLazyEnablePeerAccess));
    checkCudaErrors(cudaIpcOpenEventHandle(
        &event, *(cudaIpcEventHandle_t *)&shm->eventHandle[i]));
    ptrs.push_back(ptr);
    events.push_back(event);
  // At each iteration of the loop, each sibling process will push work on
  // their respective devices accessing the next peer mapped buffer allocated
  // by the master process (these can come from other sibling processes as
  // well). To coordinate each process' access, we force the stream to wait for
  // the work already accessing this buffer asynchronously through IPC events,
  // allowing the CPU processes to continue to queue more work.
  char *temp;
#ifdef USE_MANAGED
  cudaMallocManaged(&temp, DATA_SIZE);
#else
  cudaMalloc(&temp, DATA_SIZE);
#endif
    size_t bufferId = (i + id) % procCount;
    // Wait for the buffer to be accessed to be ready
    checkCudaErrors(cudaStreamWaitEvent(stream, events[bufferId], 0));
    // Push a simple kernel on it
    simpleKernel<<<blocks, threads, 0, stream>>>((char *)ptrs[bufferId],
                                                 DATA_SIZE, id);
#ifdef USE_FIX
    cudaMemPrefetchAsync(temp, DATA_SIZE, 0);
#endif
    checkCudaErrors(cudaGetLastError());
    cudaDeviceSynchronize();
    unsigned long long dt = dtime_usec(0);
    cudaMemcpy(temp, ptrs[bufferId], DATA_SIZE, cudaMemcpyDeviceToDevice);
    dt = dtime_usec(dt);
    std::cout << "elapsed time: " << dt/(float)USECPSEC << "s" << std::endl;
    // Signal that this buffer is ready for the next consumer
    checkCudaErrors(cudaEventRecord(events[bufferId], stream));
    // Wait for all my sibling processes to push this stage of their work
    // before proceeding to the next. This prevents siblings from racing
    // ahead and clobbering the recorded event or waiting on the wrong
    // recorded event.
    barrierWait(&shm->barrier, &shm->sense, (unsigned int)procCount);
    if (id == 0) {
      printf("Step %lld done\n", (unsigned long long)i);
  // Now wait for my buffer to be ready so I can copy it locally and verify it
  checkCudaErrors(cudaStreamWaitEvent(stream, events[id], 0));
  checkCudaErrors(cudaMemcpyAsync(&verification_buffer[0], ptrs[id], DATA_SIZE,
                                  cudaMemcpyDeviceToHost, stream));
  // And wait for all the queued up work to complete
  checkCudaErrors(cudaStreamSynchronize(stream));
  printf("Process %d: verifying...\n", id);
  // The contents should have the id of the sibling just after me
  char compareId = (char)((id + 1) % procCount);
  for (unsigned long long j = 0; j < DATA_SIZE; j++) {
    if (verification_buffer[j] != compareId) {
      printf("Process %d: Verification mismatch at %lld: %d != %d\n", id, j,
             (int)verification_buffer[j], (int)compareId);
  // Clean up!
    checkCudaErrors(cudaIpcCloseMemHandle(ptrs[i]));
    checkCudaErrors(cudaEventDestroy(events[i]));
  checkCudaErrors(cudaStreamDestroy(stream));
  printf("Process %d complete!\n", id);
static void parentProcess(char *app) {
  int devCount, i;
  std::vector<Process> processes;
  checkCudaErrors(cudaGetDeviceCount(&devCount));
  if (sharedMemoryCreate(shmName, sizeof(*shm), &info) != 0) {
    exit(EXIT_FAILURE);
  memset((void *)shm, 0, sizeof(*shm));
  // Pick all the devices that can access each other's memory for this test
  // Keep in mind that CUDA has minimal support for fork() without a
  // corresponding exec() in the child process, but in this case our
  // spawnProcess will always exec, so no need to worry.
  for (i = 0; i < devCount; i++) {
    bool allPeers = true;
    checkCudaErrors(cudaGetDeviceProperties(&prop, i));
    // CUDA IPC is only supported on devices with unified addressing
    if (!prop.unifiedAddressing) {
      printf("Device %d does not support unified addressing, skipping...\n", i);
      continue;
    // This sample requires two processes accessing each device, so we need
    // to ensure exclusive or prohibited mode is not set
    if (prop.computeMode != cudaComputeModeDefault) {
      printf("Device %d is in an unsupported compute mode for this sample\n",
             i);
      continue;
    for (int j = 0; j < shm->nprocesses; j++) {
      int canAccessPeerIJ, canAccessPeerJI;
      checkCudaErrors(
          cudaDeviceCanAccessPeer(&canAccessPeerJI, shm->devices[j], i));
      checkCudaErrors(
          cudaDeviceCanAccessPeer(&canAccessPeerIJ, i, shm->devices[j]));
      if (!canAccessPeerIJ || !canAccessPeerJI) {
        allPeers = false;
        break;
    if (allPeers) {
      // Enable peers here.  This isn't necessary for IPC, but it will
      // setup the peers for the device.  For systems that only allow 8
      // peers per GPU at a time, this acts to remove devices from CanAccessPeer
        checkCudaErrors(cudaSetDevice(i));
        checkCudaErrors(cudaDeviceEnablePeerAccess(shm->devices[j], 0));
        checkCudaErrors(cudaSetDevice(shm->devices[j]));
        checkCudaErrors(cudaDeviceEnablePeerAccess(i, 0));
      shm->devices[shm->nprocesses++] = i;
      if (shm->nprocesses >= MAX_DEVICES) break;
    } else {
      printf(
          "Device %d is not peer capable with some other selected peers, "
          "skipping\n",
          i);
  if (shm->nprocesses == 0) {
    printf("No CUDA devices support IPC\n");
    exit(EXIT_WAIVED);
  // Now allocate memory and an event for each process and fill the shared
  // memory buffer with the IPC handles to communicate
  for (i = 0; i < shm->nprocesses; i++) {
    void *ptr = NULL;
    cudaEvent_t event;
    checkCudaErrors(cudaSetDevice(shm->devices[i]));
    checkCudaErrors(cudaMalloc(&ptr, DATA_SIZE));
    checkCudaErrors(
        cudaIpcGetMemHandle((cudaIpcMemHandle_t *)&shm->memHandle[i], ptr));
    checkCudaErrors(cudaEventCreate(
        &event, cudaEventDisableTiming | cudaEventInterprocess));
    checkCudaErrors(cudaIpcGetEventHandle(
        (cudaIpcEventHandle_t *)&shm->eventHandle[i], event));
  // Launch the child processes!
    char devIdx[10];
    char *const args[] = {app, devIdx, NULL};
    Process process;
    SPRINTF(devIdx, "%d", i);
    if (spawnProcess(&process, app, args)) {
      printf("Failed to create process\n");
      exit(EXIT_FAILURE);
    processes.push_back(process);
  // And wait for them to finish
  for (i = 0; i < processes.size(); i++) {
    if (waitProcess(&processes[i]) != EXIT_SUCCESS) {
      printf("Process %d failed!\n", i);
      exit(EXIT_FAILURE);
  // Clean up!
    checkCudaErrors(cudaEventSynchronize(events[i]));
    checkCudaErrors(cudaFree(ptrs[i]));
  sharedMemoryClose(&info);
int main(int argc, char **argv) {
#if defined(__arm__) || defined(__aarch64__)
  printf("Not supported on ARM\n");
  return EXIT_WAIVED;
#else
  if (argc == 1) {
    parentProcess(argv[0]);
  } else {
    childProcess(atoi(argv[1]));
  return EXIT_SUCCESS;
#endif
$ nvcc -Icuda-samples/Common -o test cuda-samples/Common/helper_multiprocess.cpp simpleIPC.cu
simpleIPC.cu: In function ‘void parentProcess(char*)’:
simpleIPC.cu:309:17: warning: ‘sprintf’ may write a terminating nul past the end of the destination [-Wformat-overflow=]
  309 |     SPRINTF(devIdx, "%d", i);
simpleIPC.cu:309:8: note: ‘sprintf’ output between 2 and 11 bytes into a destination of size 10
$ ./test
Process 0: Starting on device 0...
elapsed time: 0.000474s
Step 0 done
Process 0: verifying...
Process 0 complete!
A 64MB copy includes 64MB reads and 64MB writes, so that is 128MB total, in 474us, for an observed bandwidth of 270GB/s.
when I run the bandwidthTest sample code on the same GPU, I get the following, indicating about 286GB/s of bandwidth available for the device-to-device case:
$ ./cuda-samples/bin/x86_64/linux/release/bandwidthTest
[CUDA Bandwidth Test] - Starting...
Running on...
 Device 0: NVIDIA GeForce GTX 1660 SUPER
 Quick Mode
 Host to Device Bandwidth, 1 Device(s)
 PINNED Memory Transfers
   Transfer Size (Bytes)        Bandwidth(GB/s)
   32000000                     12.7
 Device to Host Bandwidth, 1 Device(s)
   32000000                     12.8
 Device to Device Bandwidth, 1 Device(s)
   32000000                     286.5
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
So I don’t see any large difference between the device-to-device bandwidth available when copying from an IPC buffer to an ordinary cudaMalloc buffer, compared to copying from a cudaMalloc buffer to a cudaMalloc buffer.
If, on the other hand, I compile the modified code with -DUSE_MANAGED to turn the extra buffer into a managed memory buffer, and make no other changes, then the observed bandwidth (copying from the IPC buffer to the managed buffer) drops by about a factor of 10x:
$ nvcc -Icuda-samples/Common -o test cuda-samples/Common/helper_multiprocess.cpp simpleIPC.cu -DUSE_MANAGED
simpleIPC.cu:316:17: warning: ‘sprintf’ may write a terminating nul past the end of the destination [-Wformat-overflow=]
  316 |     SPRINTF(devIdx, "%d", i);
simpleIPC.cu:316:8: note: ‘sprintf’ output between 2 and 11 bytes into a destination of size 10
$ ./test
elapsed time: 0.004596s
Step 0 done
Process 0 complete!
If I compile the modified code with -DUSE_MANAGED -DUSE_FIX to use a managed buffer and prefetch it to the device, then the originally observed bandwidth is restored:
$ nvcc -Icuda-samples/Common -o test cuda-samples/Common/helper_multiprocess.cpp simpleIPC.cu -DUSE_MANAGED -DUSE_FIX
$ ./test
elapsed time: 0.000479s
Step 0 done
Process 0 complete!
Thank you for your patient and your demo, Robert, I will try your hints and look into my case more closely
