jetson@ubuntu:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test51-app$ sudo make
cc -c -o src/deepstream_sink_bin.o -DPLATFORM_TEGRA -I…/…/apps-common/includes -I…/…/…/includes -I…/deepstream-app/ -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-10.2/include -I include -I includes -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/json-glib-1.0 -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include src/deepstream_sink_bin.c
src/deepstream_sink_bin.c: In function ‘create_encode_file_bin’:
src/deepstream_sink_bin.c:434:6: error: ‘NvDsSinkBinSubBin {aka struct }’ has no member named ‘splitmuxsink’
bin->splitmuxsink = gst_element_factory_make(“splitmuxsink”, “splitmuxsink”);
src/deepstream_sink_bin.c:435:11: error: ‘NvDsSinkBinSubBin {aka struct }’ has no member named ‘splitmuxsink’
if (!bin->splitmuxsink) {
In file included from /usr/include/glib-2.0/gobject/gobject.h:24:0,
from /usr/include/glib-2.0/gobject/gbinding.h:29,
from /usr/include/glib-2.0/glib-object.h:23,
from /usr/include/gstreamer-1.0/gst/gstenumtypes.h:7,
from /usr/include/gstreamer-1.0/gst/gst.h:31,
from …/…/apps-common/includes/deepstream_common.h:31,
from src/deepstream_sink_bin.c:30:
src/deepstream_sink_bin.c:438:28: error: ‘NvDsSinkBinSubBin {aka struct }’ has no member named ‘splitmuxsink’
g_object_set(G_OBJECT(bin->splitmuxsink), “location”, config->output_file_path,
/usr/include/glib-2.0/gobject/gtype.h:2224:57: note: in definition of macro ‘_G_TYPE_CIC’
((ct*) g_type_check_instance_cast ((GTypeInstance*) ip, gt))
/usr/include/glib-2.0/gobject/gobject.h:51:38: note: in expansion of macro ‘G_TYPE_CHECK_INSTANCE_CAST’
#define G_OBJECT(object) (G_TYPE_CHECK_INSTANCE_CAST ((object), G_TYPE_OBJECT, GObject))
src/deepstream_sink_bin.c:438:16: note: in expansion of macro ‘G_OBJECT’
Makefile:70: recipe for target ‘src/deepstream_sink_bin.o’ failed
make: *** [src/deepstream_sink_bin.o] Error 1
jetson@ubuntu:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test51-app$ ^C
after adding splitmux into deepstream_sink_bin.c getting this error
this ais a deepstream_sinks.h
#ifndef NVGSTDS_SINKS_H
#define NVGSTDS_SINKS_H
#ifdef __cplusplus
extern “C”
#endif
#include <gst/gst.h>
typedef enum
NV_DS_SINK_FAKE = 1,
NV_DS_SINK_RENDER_EGL,
NV_DS_SINK_ENCODE_FILE,
NV_DS_SINK_UDPSINK,
NV_DS_SINK_RENDER_OVERLAY,
NV_DS_SINK_MSG_CONV_BROKER,
NV_DS_SINK_SPLITMUX,
} NvDsSinkType;
typedef enum
NV_DS_CONTAINER_MP4 = 1,
NV_DS_CONTAINER_MKV,
NV_DS_CONTAINER_SPLITMUX
} NvDsContainerType;
typedef enum
NV_DS_ENCODER_H264 = 1,
NV_DS_ENCODER_H265,
NV_DS_ENCODER_MPEG4,
NV_DS_ENCODER_SPLITMUX
} NvDsEncoderType;
typedef enum
NV_DS_ENCODER_TYPE_HW,
NV_DS_ENCODER_TYPE_SW
}NvDsEncHwSwType;
typedef struct
NvDsSinkType type;
NvDsContainerType container;
NvDsEncoderType codec;
NvDsEncHwSwType enc_type;
gint bitrate;
guint profile;
gint sync;
gchar *output_file_path;
guint gpu_id;
guint rtsp_port;
guint udp_port;
guint64 udp_buffer_size;
guint iframeinterval;
guint splitmux_interval;
gchar *splitmux_output_path;
} NvDsSinkEncoderConfig;
typedef struct
NvDsSinkType type;
gint width;
gint height;
gint sync;
gboolean qos;
gboolean qos_value_specified;
guint gpu_id;
guint nvbuf_memory_type;
guint display_id;
guint overlay_id;
guint offset_x;
guint offset_y;
} NvDsSinkRenderConfig;
typedef struct
gboolean enable;
/** MsgConv settings /
gchar config_file_path;
guint conv_payload_type;
gchar* conv_msg2p_lib;
guint conv_comp_id;
gchar* debug_payload_dir;
gboolean multiple_payloads;
gboolean conv_msg2p_new_api;
guint conv_frame_interval;
/** Broker settings /
gchar proto_lib;
gchar* conn_str;
gchar* topic;
gchar* broker_config_file_path;
guint broker_comp_id;
gboolean disable_msgconv;
gint sync;
gboolean new_api;
} NvDsSinkMsgConvBrokerConfig;
typedef struct
gboolean enable;
guint source_id;
gboolean link_to_demux;
NvDsSinkType type;
gint sync;
NvDsSinkEncoderConfig encoder_config;
NvDsSinkRenderConfig render_config;
NvDsSinkMsgConvBrokerConfig msg_conv_broker_config;
NvDsSinkMsgConvBrokerConfig splitmux_config
} NvDsSinkSubBinConfig;
typedef struct
GstElement *bin;
GstElement *queue;
GstElement *transform;
GstElement *cap_filter;
GstElement *enc_caps_filter;
GstElement *encoder;
GstElement *codecparse;
GstElement *mux;
GstElement *sink;
GstElement *splitmuxsink;
GstElement *rtppay;
gulong sink_buffer_probe;
} NvDsSinkBinSubBin;
typedef struct
GstElement *bin;
GstElement *queue;
GstElement *tee;
gint num_bins;
NvDsSinkBinSubBin sub_bins[MAX_SINK_BINS];
} NvDsSinkBin;
void destroy_sink_bin (void);
gboolean create_demux_sink_bin (guint num_sub_bins,
NvDsSinkSubBinConfig *config_array, NvDsSinkBin *bin, guint index);
void set_rtsp_udp_port_num (guint rtsp_port_num, guint udp_port_num);
#ifdef __cplusplus
#endif
#endif
this a deepstream_sink_bin.c
#include <sys/types.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/wait.h>
#include “deepstream_common.h”
#include “deepstream_sinks.h”
#include <gst/rtsp-server/rtsp-server.h>
#include <cuda_runtime_api.h>
static guint uid = 0;
static GstRTSPServer *server [MAX_SINK_BINS];
static guint server_count = 0;
static GMutex server_cnt_lock;
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
- Function to create sink bin for Display / Fakesink.
static gboolean
create_render_bin (NvDsSinkRenderConfig * config, NvDsSinkBinSubBin * bin)
gboolean ret = FALSE;
gchar elem_name[50];
GstElement *connect_to;
GstCaps *caps = NULL;
uid++;
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, config->gpu_id);
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin%d”, uid);
bin->bin = gst_bin_new (elem_name);
if (!bin->bin) {
NVGSTDS_ERR_MSG_V (“Failed to create ‘%s’”, elem_name);
goto done;
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_sink%d”, uid);
switch (config->type) {
case NV_DS_SINK_RENDER_EGL:
GST_CAT_INFO (NVDS_APP, “NVvideo renderer\n”);
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_EGL, elem_name);
g_object_set (G_OBJECT (bin->sink), “window-x”, config->offset_x,
“window-y”, config->offset_y, “window-width”, config->width,
“window-height”, config->height, NULL);
g_object_set (G_OBJECT (bin->sink), “enable-last-sample”, FALSE, NULL);
break;
case NV_DS_SINK_RENDER_OVERLAY:
#ifndef IS_TEGRA
NVGSTDS_ERR_MSG_V (“Overlay is only supported for Jetson”);
return FALSE;
#endif
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_OVERLAY, elem_name);
g_object_set (G_OBJECT (bin->sink), “display-id”, config->display_id,
NULL);
g_object_set (G_OBJECT (bin->sink), “overlay”, config->overlay_id, NULL);
g_object_set (G_OBJECT (bin->sink), “overlay-x”, config->offset_x, NULL);
g_object_set (G_OBJECT (bin->sink), “overlay-y”, config->offset_y, NULL);
g_object_set (G_OBJECT (bin->sink), “overlay-w”, config->width, NULL);
g_object_set (G_OBJECT (bin->sink), “overlay-h”, config->height, NULL);
break;
case NV_DS_SINK_FAKE:
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_FAKESINK, elem_name);
break;
default:
return FALSE;
if (!bin->sink) {
goto done;
g_object_set (G_OBJECT (bin->sink), “sync”, config->sync, “max-lateness”, -1,
“async”, FALSE, “qos”, config->qos, NULL);
if(!prop.integrated) {
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_cap_filter%d”, uid);
bin->cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, elem_name);
if (!bin->cap_filter) {
goto done;
gst_bin_add (GST_BIN (bin->bin), bin->cap_filter);
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_transform%d”, uid);
if (config->type == NV_DS_SINK_RENDER_EGL) {
if(prop.integrated) {
bin->transform =
gst_element_factory_make (NVDS_ELEM_EGLTRANSFORM, elem_name);
} else {
bin->transform = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, elem_name);
if (!bin->transform) {
goto done;
gst_bin_add (GST_BIN (bin->bin), bin->transform);
caps = gst_caps_new_empty_simple ("video/x-raw");
GstCapsFeatures *feature = NULL;
feature = gst_caps_features_new (MEMORY_FEATURES, NULL);
gst_caps_set_features (caps, 0, feature);
g_object_set (G_OBJECT (bin->cap_filter), "caps", caps, NULL);
g_object_set (G_OBJECT (bin->transform), "gpu-id", config->gpu_id, NULL);
g_object_set (G_OBJECT (bin->transform), "nvbuf-memory-type",
config->nvbuf_memory_type, NULL);
g_snprintf (elem_name, sizeof (elem_name), “render_queue%d”, uid);
bin->queue = gst_element_factory_make (NVDS_ELEM_QUEUE, elem_name);
if (!bin->queue) {
goto done;
gst_bin_add_many (GST_BIN (bin->bin), bin->queue, bin->sink, NULL);
connect_to = bin->sink;
if (bin->cap_filter) {
NVGSTDS_LINK_ELEMENT (bin->cap_filter, connect_to);
connect_to = bin->cap_filter;
if (bin->transform) {
NVGSTDS_LINK_ELEMENT (bin->transform, connect_to);
connect_to = bin->transform;
NVGSTDS_LINK_ELEMENT (bin->queue, connect_to);
NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->queue, “sink”);
ret = TRUE;
done:
if (caps) {
gst_caps_unref (caps);
if (!ret) {
NVGSTDS_ERR_MSG_V (“%s failed”, func);
return ret;
static void broker_queue_overrun (GstElement* sink_queue, gpointer user_data)
(void)sink_queue;
(void)user_data;
NVGSTDS_WARN_MSG_V("nvmsgbroker queue overrun; Older Message Buffer "
“Dropped; Network bandwidth might be insufficient\n”);
- Function to create sink bin to generate meta-msg, convert to json based on
- a schema and send over msgbroker.
static gboolean
create_msg_conv_broker_bin (NvDsSinkMsgConvBrokerConfig config,
NvDsSinkBinSubBin bin)
/ Create the subbin: → q → msgconv → msgbroker bin */
uid++;
if (!bin->bin) {
goto done;
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_queue%d”, uid);
if (!bin->queue) {
goto done;
/** set threshold on queue to avoid pipeline choke when broker is stuck on network
- leaky=2 (2): downstream - Leaky on downstream (old buffers) */
g_object_set(G_OBJECT(bin->queue), “leaky”, 2, NULL);
g_object_set(G_OBJECT(bin->queue), “max-size-buffers”, 20, NULL);
g_signal_connect (G_OBJECT (bin->queue), “overrun”,
G_CALLBACK (broker_queue_overrun), bin);
/* Create msg converter to generate payload from buffer metadata */
if (config->disable_msgconv)
bin->transform = gst_element_factory_make (“queue”, elem_name);
else
bin->transform = gst_element_factory_make (NVDS_ELEM_MSG_CONV, elem_name);
goto done;
if (!config->disable_msgconv)
g_object_set (G_OBJECT(bin->transform), “config”, config->config_file_path,
“msg2p-lib”, (config->conv_msg2p_lib ? config->conv_msg2p_lib : NULL),
“payload-type”, config->conv_payload_type,
“comp-id”, config->conv_comp_id,
“debug-payload-dir”, config->debug_payload_dir,
“multiple-payloads”, config->multiple_payloads,
“msg2p-newapi”, config->conv_msg2p_new_api,
“frame-interval”, config->conv_frame_interval,
NULL);
/* Create msg broker to send payload to server */
bin->sink = gst_element_factory_make (NVDS_ELEM_MSG_BROKER, elem_name);
if (!bin->sink) {
goto done;
g_object_set (G_OBJECT(bin->sink), “proto-lib”, config->proto_lib,
“conn-str”, config->conn_str,
“topic”, config->topic,
“sync”, config->sync, “async”, FALSE,
“config”, config->broker_config_file_path,
“comp-id”, config->broker_comp_id,
“new-api”, config->new_api,
NULL);
bin->queue, bin->transform, bin->sink,
NULL);
NVGSTDS_LINK_ELEMENT (bin->queue, bin->transform);
NVGSTDS_LINK_ELEMENT (bin->transform, bin->sink);
ret = TRUE;
done:
if (!ret) {
return ret;
- Probe function to drop upstream “GST_QUERY_SEEKING” query from h264parse element.
- This is a WAR to avoid memory leaks from h264parse element
static GstPadProbeReturn
seek_query_drop_prob (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
if (GST_PAD_PROBE_INFO_TYPE(info) &
GST_PAD_PROBE_TYPE_QUERY_UPSTREAM)
GstQuery *query = GST_PAD_PROBE_INFO_QUERY(info);
if(GST_QUERY_TYPE (query) == GST_QUERY_SEEKING)
return GST_PAD_PROBE_DROP;
return GST_PAD_PROBE_OK;
- Function to create sink bin to generate encoded output.
static gboolean
create_encode_file_bin (NvDsSinkEncoderConfig * config, NvDsSinkBinSubBin * bin)
int probe_id = 0;
gulong bitrate = config->bitrate;
guint profile = config->profile;
uid++;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
goto done;
goto done;
if (config->codec == NV_DS_ENCODER_MPEG4 || config->enc_type == NV_DS_ENCODER_TYPE_SW)
caps = gst_caps_from_string (“video/x-raw, format=I420”);
else
caps = gst_caps_from_string (“video/x-raw(memory:NVMM), format=I420”);
g_object_set (G_OBJECT (bin->cap_filter), “caps”, caps, NULL);
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_encoder%d”, uid);
switch (config->codec) {
case NV_DS_ENCODER_H264:
if (config->enc_type == NV_DS_ENCODER_TYPE_SW)
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_SW, elem_name);
else
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_HW, elem_name);
break;
case NV_DS_ENCODER_H265:
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_SW, elem_name);
else
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_HW, elem_name);
break;
case NV_DS_ENCODER_MPEG4:
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_MPEG4, elem_name);
break;
default:
goto done;
if (!bin->encoder) {
goto done;
NVGSTDS_ELEM_ADD_PROBE(probe_id,
bin->encoder, “sink”,
seek_query_drop_prob, GST_PAD_PROBE_TYPE_QUERY_UPSTREAM, bin);
probe_id = probe_id;
if (config->codec == NV_DS_ENCODER_MPEG4)
config->enc_type = NV_DS_ENCODER_TYPE_SW;
if(prop.integrated && config->enc_type == NV_DS_ENCODER_TYPE_HW) {
g_object_set (G_OBJECT (bin->encoder), “bufapi-version”, 1, NULL);
if (config->enc_type == NV_DS_ENCODER_TYPE_HW) {
g_object_set (G_OBJECT (bin->encoder), “profile”, profile, NULL);
g_object_set (G_OBJECT (bin->encoder), “iframeinterval”, config->iframeinterval, NULL);
g_object_set (G_OBJECT (bin->encoder), “bitrate”, bitrate, NULL);
} else {
else {
//bitrate is in kbits/sec for software encoder x264enc and x265enc
g_object_set (G_OBJECT (bin->encoder), “bitrate”, bitrate / 1000, NULL);
bin->codecparse = gst_element_factory_make (“h264parse”, “h264-parser”);
break;
bin->codecparse = gst_element_factory_make (“h265parse”, “h265-parser”);
break;
bin->codecparse = gst_element_factory_make (“mpeg4videoparse”, “mpeg4-parser”);
break;
default:
goto done;
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_mux%d”, uid);
switch (config->container) {
case NV_DS_CONTAINER_MP4:
bin->mux = gst_element_factory_make (NVDS_ELEM_MUX_MP4, elem_name);
break;
case NV_DS_CONTAINER_MKV:
bin->mux = gst_element_factory_make (NVDS_ELEM_MKV, elem_name);
break;
default:
goto done;
if (!bin->mux) {
goto done;
NVGSTDS_ERR_MSG_V(“Failed to create ‘splitmuxsink’”);
goto done;
“muxer”, bin->mux, NULL);
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_FILE, elem_name);
if (!bin->sink) {
goto done;
g_object_set (G_OBJECT (bin->sink), “location”, config->output_file_path,
“sync”, config->sync, “async”, FALSE, NULL);
g_object_set (G_OBJECT (bin->transform), “gpu-id”, config->gpu_id, NULL);
bin->transform, bin->codecparse, bin->cap_filter,
bin->encoder, bin->mux, bin->sink, NULL);
NVGSTDS_LINK_ELEMENT (bin->transform, bin->cap_filter);
NVGSTDS_LINK_ELEMENT (bin->cap_filter, bin->encoder);
NVGSTDS_LINK_ELEMENT (bin->encoder, bin->codecparse);
NVGSTDS_LINK_ELEMENT (bin->codecparse, bin->mux);
NVGSTDS_LINK_ELEMENT (bin->mux, bin->sink);
ret = TRUE;
done:
if (caps) {
if (!ret) {
return ret;
static gboolean
start_rtsp_streaming (guint rtsp_port_num, guint updsink_port_num,
NvDsEncoderType enctype, guint64 udp_buffer_size)
GstRTSPMountPoints *mounts;
GstRTSPMediaFactory *factory;
char udpsrc_pipeline[512];
char port_num_Str[64] = { 0 };
char *encoder_name;
if (enctype == NV_DS_ENCODER_H264) {
encoder_name = “H264”;
} else if (enctype == NV_DS_ENCODER_H265) {
encoder_name = “H265”;
} else {
return FALSE;
if (udp_buffer_size == 0)
udp_buffer_size = 512 * 1024;
sprintf (udpsrc_pipeline,
"( udpsrc name=pay0 port=%d buffer-size=%lu caps="application/x-rtp, media=video, "
“clock-rate=90000, encoding-name=%s, payload=96 " )”,
updsink_port_num, udp_buffer_size, encoder_name);
sprintf (port_num_Str, “%d”, rtsp_port_num);
g_mutex_lock (&server_cnt_lock);
server [server_count] = gst_rtsp_server_new ();
g_object_set (server [server_count], “service”, port_num_Str, NULL);
mounts = gst_rtsp_server_get_mount_points (server [server_count]);
factory = gst_rtsp_media_factory_new ();
gst_rtsp_media_factory_set_launch (factory, udpsrc_pipeline);
gst_rtsp_mount_points_add_factory (mounts, “/ds-test”, factory);
g_object_unref (mounts);
gst_rtsp_server_attach (server [server_count], NULL);
server_count++;
g_mutex_unlock (&server_cnt_lock);
g_print
(“\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n”,
rtsp_port_num);
return TRUE;
static gboolean
create_udpsink_bin (NvDsSinkEncoderConfig * config, NvDsSinkBinSubBin * bin)
gchar encode_name[50];
gchar rtppay_name[50];
int probe_id = 0;
//guint rtsp_port_num = g_rtsp_port_num++;
uid++;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
goto done;
goto done;
else
g_snprintf (encode_name, sizeof (encode_name), “sink_sub_bin_encoder%d”, uid);
g_snprintf (rtppay_name, sizeof (rtppay_name), “sink_sub_bin_rtppay%d”, uid);
bin->rtppay = gst_element_factory_make (“rtph264pay”, rtppay_name);
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_SW, encode_name);
else
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_HW, encode_name);
break;
g_object_set (G_OBJECT (bin->codecparse), “config-interval”, -1, NULL);
bin->rtppay = gst_element_factory_make (“rtph265pay”, rtppay_name);
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_SW, encode_name);
else
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_H265_HW, encode_name);
break;
default:
goto done;
NVGSTDS_ERR_MSG_V (“Failed to create ‘%s’”, encode_name);
goto done;
if (!bin->rtppay) {
NVGSTDS_ERR_MSG_V (“Failed to create ‘%s’”, rtppay_name);
goto done;
if (config->enc_type == NV_DS_ENCODER_TYPE_SW) {
g_object_set (G_OBJECT (bin->encoder), “bitrate”, config->bitrate/1000, NULL);
} else {
g_object_set (G_OBJECT (bin->encoder), “bitrate”, config->bitrate, NULL);
g_object_set (G_OBJECT (bin->encoder), “profile”, config->profile, NULL);
g_object_set (G_OBJECT (bin->encoder), “preset-level”, 1, NULL);
g_object_set (G_OBJECT (bin->encoder), “insert-sps-pps”, 1, NULL);
} else {
g_snprintf (elem_name, sizeof (elem_name), “sink_sub_bin_udpsink%d”, uid);
bin->sink = gst_element_factory_make (“udpsink”, elem_name);
if (!bin->sink) {
goto done;
g_object_set (G_OBJECT (bin->sink), “host”, “224.224.255.255”, “port”,
config->udp_port, “async”, FALSE, “sync”, 0, NULL);
bin->queue, bin->cap_filter, bin->transform,
bin->encoder, bin->codecparse, bin->rtppay, bin->sink, NULL);
NVGSTDS_LINK_ELEMENT (bin->codecparse, bin->rtppay);
NVGSTDS_LINK_ELEMENT (bin->rtppay, bin->sink);
ret = TRUE;
ret = start_rtsp_streaming (config->rtsp_port, config->udp_port, config->codec,
config->udp_buffer_size);
if (ret != TRUE) {
g_print (“%s: start_rtsp_straming function failed\n”, func);
done:
if (caps) {
if (!ret) {
return ret;
gboolean
create_sink_bin (guint num_sub_bins, NvDsSinkSubBinConfig * config_array,
NvDsSinkBin * bin, guint index)
guint i;
bin->bin = gst_bin_new (“sink_bin”);
if (!bin->bin) {
NVGSTDS_ERR_MSG_V (“Failed to create element ‘sink_bin’”);
goto done;
bin->queue = gst_element_factory_make (NVDS_ELEM_QUEUE, “sink_bin_queue”);
if (!bin->queue) {
NVGSTDS_ERR_MSG_V (“Failed to create element ‘sink_bin_queue’”);
goto done;
gst_bin_add (GST_BIN (bin->bin), bin->queue);
bin->tee = gst_element_factory_make (NVDS_ELEM_TEE, “sink_bin_tee”);
if (!bin->tee) {
NVGSTDS_ERR_MSG_V (“Failed to create element ‘sink_bin_tee’”);
goto done;
gst_bin_add (GST_BIN (bin->bin), bin->tee);
NVGSTDS_LINK_ELEMENT (bin->queue, bin->tee);
g_object_set (G_OBJECT (bin->tee), “allow-not-linked”, TRUE, NULL);
for (i = 0; i < num_sub_bins; i++) {
if (!config_array[i].enable) {
continue;
if (config_array[i].source_id != index) {
continue;
if (config_array[i].link_to_demux) {
continue;
switch (config_array[i].type) {
config_array[i].render_config.type = config_array[i].type;
config_array[i].render_config.sync = config_array[i].sync;
if (!create_render_bin (&config_array[i].render_config,
&bin->sub_bins[i]))
goto done;
break;
case NV_DS_SINK_ENCODE_FILE:
config_array[i].encoder_config.sync = config_array[i].sync;
if (!create_encode_file_bin (&config_array[i].encoder_config,
&bin->sub_bins[i]))
goto done;
break;
case NV_DS_SINK_UDPSINK:
if (!create_udpsink_bin (&config_array[i].encoder_config,
&bin->sub_bins[i]))
goto done;
break;
case NV_DS_SINK_MSG_CONV_BROKER:
config_array[i].msg_conv_broker_config.sync = config_array[i].sync;
if (!create_msg_conv_broker_bin (&config_array[i].msg_conv_broker_config,
&bin->sub_bins[i]))
goto done;
break;
default:
goto done;
if(config_array[i].type != NV_DS_SINK_MSG_CONV_BROKER) {
gst_bin_add (GST_BIN (bin->bin), bin->sub_bins[i].bin);
if (!link_element_to_tee_src_pad (bin->tee, bin->sub_bins[i].bin)) {
goto done;
bin->num_bins++;
if (bin->num_bins == 0) {
NvDsSinkRenderConfig config;
config.type = NV_DS_SINK_FAKE;
if (!create_render_bin (&config, &bin->sub_bins[0]))
goto done;
gst_bin_add (GST_BIN (bin->bin), bin->sub_bins[0].bin);
if (!link_element_to_tee_src_pad (bin->tee, bin->sub_bins[0].bin)) {
goto done;
bin->num_bins = 1;
ret = TRUE;
done:
if (!ret) {
return ret;
gboolean
create_demux_sink_bin (guint num_sub_bins, NvDsSinkSubBinConfig * config_array,
guint i;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
if (!bin->tee) {
goto done;
continue;
if (!config_array[i].link_to_demux) {
continue;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
default:
goto done;
goto done;
bin->num_bins++;
goto done;
goto done;
bin->num_bins = 1;
ret = TRUE;
done:
if (!ret) {
return ret;
static GstRTSPFilterResult
client_filter (GstRTSPServer * server, GstRTSPClient * client,
gpointer user_data)
return GST_RTSP_FILTER_REMOVE;
void
destroy_sink_bin ()
GstRTSPSessionPool pool;
guint i = 0;
for (i = 0; i < server_count; i++) {
mounts = gst_rtsp_server_get_mount_points (server [i]);
gst_rtsp_mount_points_remove_factory (mounts, “/ds-test”);
gst_rtsp_server_client_filter (server [i], client_filter, NULL);
pool = gst_rtsp_server_get_session_pool (server [i]);
gst_rtsp_session_pool_cleanup (pool);
g_object_unref (pool);
- Copyright (c) 2018-2021, NVIDIA CORPORATION. All rights reserved.
- Permission is hereby granted, free of charge, to any person obtaining a
- copy of this software and associated documentation files (the “Software”),
- to deal in the Software without restriction, including without limitation
- the rights to use, copy, modify, merge, publish, distribute, sublicense,
- and/or sell copies of the Software, and to permit persons to whom the
- Software is furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- DEALINGS IN THE SOFTWARE.
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
static gboolean
uid++;
if (!bin->bin) {
goto done;
break;
#ifndef IS_TEGRA
return FALSE;
#endif
NULL);
break;
break;
default:
return FALSE;
if (!bin->sink) {
goto done;
goto done;
bin->transform =
} else {
goto done;
if (!bin->queue) {
goto done;
ret = TRUE;
done:
if (caps) {
if (!ret) {
return ret;
(void)sink_queue;
(void)user_data;
static gboolean
uid++;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
else
goto done;
NULL);
if (!bin->sink) {
goto done;
NULL);
NULL);
ret = TRUE;
done:
if (!ret) {
return ret;
gpointer u_data)
static gboolean
int probe_id = 0;
uid++;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
goto done;
goto done;
else
else
break;
else
break;
break;
default:
goto done;
goto done;
} else {
else {
break;
break;
break;
default:
goto done;
break;
break;
default:
goto done;
if (!bin->mux) {
goto done;
goto done;
if (!bin->sink) {
goto done;
ret = TRUE;
done:
if (caps) {
if (!ret) {
return ret;
static gboolean
char *encoder_name;
} else {
return FALSE;
server_count++;
g_print
rtsp_port_num);
return TRUE;
static gboolean
int probe_id = 0;
uid++;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
goto done;
goto done;
else
else
break;
else
break;
default:
goto done;
goto done;
if (!bin->rtppay) {
goto done;
} else {
} else {
if (!bin->sink) {
goto done;
ret = TRUE;
if (ret != TRUE) {
done:
if (caps) {
if (!ret) {
return ret;
gboolean
guint i;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
if (!bin->tee) {
goto done;
continue;
continue;
continue;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
default:
goto done;
goto done;
bin->num_bins++;
goto done;
goto done;
bin->num_bins = 1;
ret = TRUE;
done:
if (!ret) {
return ret;
gboolean
guint i;
if (!bin->bin) {
goto done;
if (!bin->queue) {
goto done;
if (!bin->tee) {
goto done;
continue;
continue;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
&bin->sub_bins[i]))
goto done;
break;
default:
goto done;
goto done;
bin->num_bins++;
goto done;
goto done;
bin->num_bins = 1;
ret = TRUE;
done:
if (!ret) {
return ret;
gpointer user_data)
void
destroy_sink_bin ()
GstRTSPSessionPool *pool;
guint i = 0;
