Is there an example config file on how to launch multiple mono cameras with isaac ros argus camera. I followed this guide . I want to start 4-6 cameras, all in mono mode, not stereo. However, I only manage to start one camera. Also, when changing parameters in the config file the changes are not reflected when launching the node.
I would be nice if someone has an example config file with at least 2 cameras in mono mode.
Thanks,
Hi @gwaibel
The best way is to make your new ROS 2 launch file with a setup for both cameras.
An example of running two mono cameras can be seen in the file below
import launch
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
argus_mono_first_node = ComposableNode(
name='argus_mono_first',
package='isaac_ros_argus_camera',
plugin='nvidia::isaac_ros::argus::ArgusMonoNode',
remappings=[('left/image_raw', 'first/image_raw'), ('left/camera_info', 'first/camera_info')],
parameters=[{
'camera_id': 0,
argus_mono_second_node = ComposableNode(
name='argus_mono_second',
remappings=[('left/image_raw', 'second/image_raw'), ('left/camera_info', 'second/camera_info')],
parameters=[{
'camera_id': 1,
argus_mono_container = ComposableNodeContainer(
name='argus_mono_container',
package='rclcpp_components',
executable='component_container_mt',
composable_node_descriptions=[argus_mono_first_node, argus_mono_second_node],
namespace='',
output='screen',
arguments=['--ros-args', '--log-level', 'info'],
return launch.LaunchDescription([argus_mono_container])
system
Closed
May 16, 2024, 3:19pm
4
