On r28.1 we put the dtb file to the kernel/dtb directory and flash the system,it will effective ,but on r28.2,it does not work.in other words,the changed part are not all effective.such like I enabled the usb_ss0 and usb_ss2,only the usb_ss0 worked .
How to make the dtb file effective on R28.2?
Hi qinyyuu,
So you following the steps to flash kernel-dtb but do not work?
Have you checked device tree at /proc/device-tree ?
@DaneLLL
Yes,I followed the steps to flash kernel-dtb it does not work.only part are working.
In the flashing ,the dtb file have compiled?
@DaneLLL
No, you have to compile it to have new dtb and then flash via the command.
Hi DaneLLL
Yes, I have already compiled it and put it to kernel/dtb.
I mean in the process of flashing,will be the script flash.sh recompile?
Flash.sh just places a copy of the file in the Jetson dtb partition. You’d have to copy in a correctly modified version to the correct place before running the flash.sh command.
Hi linuxdev
I put the dtb file into kernel/dtb. Is this correct?
The same modified dtb file, I use other method all is working. However, the flash method is not acceptable
What did you name the file? I’m thinking the “tegra186-quill-p3310-1000-c03-00-base.dtb” file is the correct one, but I’d have to double check to be certain.
Hi qinyyuu,
Please try to replace all tegra186-quill-p3310-1000-c03-00-base.dtb
https://devtalk.nvidia.com/default/topic/1024105/jetson-tx2/tx2-usb2-0-not-working-how-to-fix-it/post/5210056/#5210056
