How to measure time IN a kernel?
Hi!
I want to measure the time elapsed IN a kernel, not how long the kernel execution overall is.
Something like this:
some_kernel(){
start timer
do_something1
<-----measure the time elapsed till here------->
do_something2
do_something3
Is there any way to do that?
You can use a bit of inline assembly to read the PTX cycle counter:
__device__ unsigned int get_clock(void)
  unsigned int clock;
  asm("mov.u32 %0, %clock;" : "=r"(clock) );
  return clock;
It seems to run at half the shader clock.
  unsigned int clock;
  return clock;
Thank you very much!
That works very well for me
You could also use the built-in method!
clock_t clock();
See section B.10 of the CUDA 3.1 programming guide for more info. The inline PTX is just is effective though…
clock_t clock();
Thanks, Profquail!
I somehow had in the back of my head that there was a CUDA function for this already, but apparently missed it when I quickly scanned the Programming Guide appendices to check.
Thanks, Profquail!
Thank you both very much, love this board :)
