I am using two Orin modules for RP/EP communication and have encountered two issues.
When using “pcie -v” command, the result shows only a 64K BAR size. How to modify BAR size?
please refer to PCIe Endpoint Mode — Jetson Linux Developer Guide documentation
Yes, I have read this article. Using the configuration method described in the article, the BAR size of the data is 64K. I want to increase the size of the BAR size. How can I do that?
Go to the driver code and directly modify it in the driver…
Sorry for the late response, is this still an issue to support? Thanks
