How to modify camera device driver
My end goal is a jetson mipi without i2c in fpga.
I first confirmed that the jetson and mipi interface with imx219 pi-cam.
After looking through many articles, I thought that I should study the sensor software driver program first.
However, I couldn’t find the following code used as an example.
  • tegra194-camera-imx185-a00.dtsi
  • imx185_1.c
I have no knowledge of kernel and device tree.
So I need an example using the jetson xavier nx that I am using.
I ask you because you seem to be kind to answer. @ShaneCCC
Have reference to below document. You also able check the kernel customize chapter to get all kernel source and device tree for reference.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/camera_sensor_prog.47.1.html#
Thanks for your responds
I do step by step.
I face the problem below.
now, my step is
Building the NVIDIA KERNEL - To build the jetson Linux Kernel - step 4 : Execute the following commands to build the kernel including all DTBs and modules
( make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j
make[1]: Entering directory '/home/eslab/dev'
arch/arm64/Makefile:49: LSE atomics not supported by binutils
/home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 1: /home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: cannot open @@: No such file
/home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 1: /home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: ELF: not found
/home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 3: /home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Syntax error: "(" unexpected
  CHK     include/config/kernel.release
  GEN     ./Makefile
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  Using /home/eslab/Linux_for_Tegra/source/public/kernel/kernel-4.9 as source for kernel
  CC      scripts/mod/empty.o
/bin/sh: 1: /home/eslab/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error
/home/eslab/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:335: recipe for target 'scripts/mod/empty.o' failed
make[3]: *** [scripts/mod/empty.o] Error 2
make[3]: *** Waiting for unfinished jobs....
  CC      scripts/mod/devicetable-offsets.s
/home/eslab/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:155: recipe for target 'scripts/mod/devicetable-offsets.s' failed
make[3]: *** [scripts/mod/devicetable-offsets.s] Error 2
/home/eslab/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:649: recipe for target 'scripts/mod' failed
make[2]: *** [scripts/mod] Error 2
make[2]: *** Waiting for unfinished jobs....
/home/eslab/Linux_for_Tegra/source/public/kernel/kernel-4.9/Makefile:589: recipe for target 'scripts' failed
make[1]: *** [scripts] Error 2
make[1]: Leaving directory '/home/eslab/dev'
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
Did you install the toolchain?
Did you build it on host PC or Xavier NX?
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/xavier_toolchain.html#wwpID0EQHA
I did build it on Xavier NX.
Do I build it on Host PC?
The document guidance is build on host PC.
You can build on NX but the toolchain is different. Have reference below link for building on NX.
