Errors:
arch/arm64/boot/dts/Makefile:132: target ‘arch/arm64/boot/dts/ddot’ given more than once in the same rule
make[1]: *** No rule to make target ‘arch/arm64/boot/dts/…//hardware/nvidia/platform/t19x/mccoy/kernel-dts/tegra194-p2888-0004-e3900-0000.dts’, needed by ‘arch/arm64/boot/dts/ddot//hardware/nvidia/platform/t19x/mccoy/kernel-dts/tegra194-p2888-0004-e3900-0000.dtb’. Stop.
make[1]: *** Waiting for unfinished jobs…
DTC arch/arm64/boot/dts/ddot
cc1: fatal error: arch/arm64/boot/dts/…: No such file or directory
Hello, ayyappan.rathinam
For SPE firmware, I checked the BSP package, and there’s no SPE upgrade from 32.5 to 32.7.
So you can go forward with 32.7.3 BSP, and test with 32.5 SPE source.
compilation terminated.
make[1]: *** [arch/arm64/boot/dts/Makefile:133: arch/arm64/boot/dts/ddot] Error 1
make: *** [arch/arm64/Makefile:154: dtbs] Error 2
Regarding the above error, that file is generated from a “make Image” command (adjusted for path and tools, e.g., the “O=/some/where/temporary” would change the $TOP for output of content during a build). I don’t know about the particular firmware build command you used, but if it requires the Image file, then perhaps it is as simple as building the Image target (configured correctly) and then firmware might build.
