L4T 32.7.1 Device Tree Compilation Fails
I’m trying to compile L4T 32.7.1 source code but it fails.
Here is what I’ve done:
  1. Extracted Linux_for_Tegra archive that downloaded from: https://developer.nvidia.com/embedded/l4t/r32_release_v7.1/t186/jetson_linux_r32.7.1_aarch64.tbz2
  2. I executed these commands in Linux_for_Tegra directory:
 ./source_sync.sh -t tegra-l4t-r32.7.1
export DEVDIR=/some/directory/Linux_for_Tegra
export CROSS_COMPILE=/some/other/directory/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export KERNEL_MODULES_OUT=$DEVDIR/images/modules
export TEGRA_KERNEL_OUT=$DEVDIR/images
export ARCH=arm64
export LOCALVERSION=-tegra
  1. Then I executed these commands to compile the source code:
cd $DEVDIR/sources/kernel/kernel-4.9/
make mrproper
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j7
A few seconds later, compilation fails while compiling the device tree for t19x platform:
make[1]: Entering directory '/some/directory/Linux_for_Tegra/images'
  GEN     ./Makefile
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config/kernel.release
  GEN     ./Makefile
  UPD     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  UPD     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
  Using /some/directory/Linux_for_Tegra/sources/kernel/kernel-4.9 as source for kernel
  CHK     scripts/mod/devicetable-offsets.h
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00-auo-1080p-edp.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-android-devkit.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-imx274-dp-hdmi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-base-p2595-0000-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-p2595-0000-a00-00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit_as_TM660M.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-as-p3448-0003.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000-hdmi-dsi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000-kexec.dtb
  CC      kernel/bounds.s
  CHK     include/generated/timeconst.h
  UPD     include/generated/timeconst.h
  CHK     include/generated/bounds.h
  UPD     include/generated/bounds.h
  CC      arch/arm64/kernel/asm-offsets.s
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000-imx274-hdmi.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000-imx185_v1.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000-maxn.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-e3366-1199.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0006-e3366-1199.dtb
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-as-0006-p2822-0000.dtb
make[2]: *** No rule to make target 'arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen-industrial/kernel-dts/tegra194-p2888-0008-e3366-1199.dts', needed by 'arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts/tegra194-p2888-0008-e3366-1199.dtb'.  Stop.
make[2]: *** Waiting for unfinished jobs....
  DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-as-p3668-p2822-0000.dtb
  CHK     include/generated/asm-offsets.h
  UPD     include/generated/asm-offsets.h
  CALL    /some/directory/Linux_for_Tegra/sources/kernel/kernel-4.9/scripts/checksyscalls.sh
arch/arm64/Makefile:154: recipe for target 'dtbs' failed
make[1]: *** [dtbs] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/some/directory/Linux_for_Tegra/images'
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
After I deleted “Linux_for_Tegra/sources/hardware/nvidia/platform/t19x” directory from the source code, I managed to compile the device tree and the kernel without any error.
What am I doing wrong?
Are you cross-compiling or is it native compile? If native, then don’t specify ARCH. If cross-compile, then you failed to specify the cross toolchain. Either way, you should specify a build target and not build “everything”. An example target which was correct is “tegra_defconfig”.
If you want to build anything other than the kernel itself, and have not taken steps to propagate the configuration, then the configuration you picked is unlikely to be used. If for example you build “Image” target, then all configuration will be propagated. If you fail to do this, then you need extra preparation, e.g., the “modules_prepare” target.
Did you intend to build firmware, device tree, modules, and all kernel formats? This is what you get by not specifying a target. If you just want the device tree, then after configuration is correct, then build target “dtbs”. What is it you want to build?
No, I’m compiling the kernel with my x86 machine to Jetson so the ARCH=arm64 is necessary. I also exported the toolchain path (gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu) as seen in my first post. Linaro version is correct according to Nvidia’s documentation.
I modified some device driver’s kernel source code and their device tree files so I need to compile all of the sources.
The compilation steps that I have written in my first post was working for L4T 32.4.4 but not for L4T 32.7.1. That’s the problem actually.
The file hardware/nvidia/platform/t19x/galen-industrial-dts/kernal-dts/Makefile has a wrong path. It should be
makefile-path := platform/t19x/galen-industrial-dts/kernel-dts
That solved my problem, thank you gabephan.
You can also fix this by modifying the source sync path.
k:hardware/nvidia/platform/t19x/galen-industrial-dts/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/galen-industrial-dts.git:
to
k:hardware/nvidia/platform/t19x/galen-industrial/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/galen-industrial-dts.git:
