I’m processing an RTSP stream from a wireless IP Camera processing (or plan to ) the stream with OpenCV and pushing the processed streamed to an RTSP server with Gstreamer. Although I’m using the AGX hardware encorder (omxh264enc), I still have about 7 seconds of latency.
Is there anything I can do to optimize the omxh264enc setting to reduce the latency?
Can you make general recommendations on how I can reduce the pipeline’s latency?
My setup:
AGX, OpenCV with Gstreamer.
My Code:
import numpy as np
from multiprocessing import Process
import cv2
cap = cv2.VideoCapture(‘rtsp://192.168.0.6:8080/h264_pcm.sdp’)
gst_str= ("appsrc ! autovideoconvert ! omxh264enc bitrate=4000000 ! video/x-h264 ! rtspclientsink location=rtsp://localhost:8554/mystream ");
four_cc = cv2.VideoWriter_fourcc(*‘X264’)
out = cv2.VideoWriter(gst_str, cv2.CAP_GSTREAMER,four_cc, 30, (1280, 720))
while(cap.isOpened()):
ret, frame = cap.read()
out.write(frame)
if cv2.waitKey(20) & 0xFF == ord(‘q’):
break
cap.release()
out.release()
cv2.destroyAllWindows()
Thank you,
