I am facing an issue of accuracy about my code which performs a high number (128, 256, 512) of 4x4 matrix inversion. When I use the original version, i.e the numpy classical function np.linalg.inv or np.linakg.pinv, everything works fine.
Unfortunately, with the CUDA code below, I get nan and inf values into inverted matrix.
To be more explicit, here is an example of matrix to invert :
2.120771107884677649e+09 0.000000000000000000e+00 0.000000000000000000e+00 0.000000000000000000e+00
0.000000000000000000e+00 3.557266600921528288e+27 3.557266600921528041e+07 3.557266600921528320e+17
0.000000000000000000e+00 3.557266600921528041e+07 3.557266600921528288e+27 3.557266600921528041e+07
0.000000000000000000e+00 3.557266600921528320e+17 3.557266600921528041e+07 1.778633300460764144e+27
If I use classical numpy “inv”, I get for the following inverted 4x4 matrix :
4.715266047722758306e-10 0.000000000000000000e+00 0.000000000000000000e+00 0.000000000000000000e+00
0.000000000000000000e+00 2.811147187396482366e-28 -2.811147186834252285e-48 -5.622294374792964645e-38
0.000000000000000000e+00 -2.811147186834252285e-48 2.811147187396482366e-28 -5.622294374230735768e-48
0.000000000000000000e+00 -5.622294374792964645e-38 -5.622294374230735768e-48 5.622294374792964732e-28
To check the validity of this inverse matrix, I have multiplied it by original matrix and the result is the identity matrix.
But with CUDA GPU inversion, I get after the inversion this matrix :
0.000000000000000000e+00 0.000000000000000000e+00 0.000000000000000000e+00 0.000000000000000000e+00
-inf -inf -9.373764907941219970e-01 -inf
inf nan -inf nan
So, I woul like to increase the precision into my CUDA kernel or python code to avoid these nanand inf values.
Here is the CUDA kernel code and calling part of my main code (I have commented the classical method with numpy inv function :
# Create arrayFullCross_vec array
arrayFullCross_vec = np.zeros((dimBlocks,dimBlocks,integ_prec,integ_prec))
invCrossMatrix_gpu = np.zeros((dimBlocks*dimBlocks*integ_prec**2))
invCrossMatrix = np.zeros((dimBlocks,dimBlocks,integ_prec,integ_prec))
# Build observables covariance matrix
arrayFullCross_vec = buildObsCovarianceMatrix4_vec(k_ref, mu_ref, ir)
# Compute integrand from covariance matrix
for r_p in range(integ_prec):
for s_p in range(integ_prec):
# original version (without GPU)
invCrossMatrix[:,:,r_p,s_p] = np.linalg.inv(arrayFullCross_vec[:,:,r_p,s_p])
# GPU version
invCrossMatrix_gpu = gpuinv4x4(arrayFullCross_vec.flatten(),integ_prec**2)
invCrossMatrix = invCrossMatrix_gpu.reshape(dimBlocks,dimBlocks,integ_prec,integ_prec)
and here the CUDA kernel code and gpuinv4x4 function :
kernel = SourceModule("""
__device__ unsigned getoff(unsigned &off){
unsigned ret = off & 0x0F;
off = off >> 4;
return ret;
const int block_size = 256;
const unsigned tmsk = 0xFFFFFFFF;
// in-place is acceptable i.e. out == in)
// T = double or double only
typedef double T;
__global__ void inv4x4(const T * __restrict__ in, T * __restrict__ out, const size_t n, const unsigned * __restrict__ pat){
__shared__ T si[block_size];
size_t idx = threadIdx.x+blockDim.x*blockIdx.x;
if (idx < n*16){
si[threadIdx.x] = in[idx];
unsigned lane = threadIdx.x & 15;
unsigned sibase = threadIdx.x & 0x03F0;
__syncwarp();
unsigned off = pat[lane];
T a,b;
a = si[sibase + getoff(off)];
a *= si[sibase + getoff(off)];
if (!getoff(off)) a = -a;
b = si[sibase + getoff(off)];
b *= si[sibase + getoff(off)];
if (getoff(off)) a += b;
else a -=b;
off = pat[lane+16];
else a -=b;
else a -=b;
off = pat[lane+32];
else a -=b;
else a -=b;
T det = si[sibase + (lane>>2)]*a;
det += __shfl_down_sync(tmsk, det, 4, 16); // first add
det += __shfl_down_sync(tmsk, det, 8, 16); // second add
det = __shfl_sync(tmsk, det, 0, 16); // broadcast
out[idx] = a / det;
# python function for inverting 4x4 matrices
# n should be an even number
def gpuinv4x4(inp, n):
# internal constants not to be modified
hpat = ( 0x0EB51FA5, 0x1EB10FA1, 0x0E711F61, 0x1A710B61, 0x1EB40FA4, 0x0EB01FA0, 0x1E700F60, 0x0A701B60, 0x0DB41F94, 0x1DB00F90, 0x0D701F50, 0x19700B50, 0x1DA40E94, 0x0DA01E90, 0x1D600E50, 0x09601A50, 0x1E790F69, 0x0E391F29, 0x1E350F25, 0x0A351B25, 0x0E781F68, 0x1E380F28, 0x0E341F24, 0x1A340B24, 0x1D780F58, 0x0D381F18, 0x1D340F14, 0x09341B14, 0x0D681E58, 0x1D280E18, 0x0D241E14, 0x19240A14, 0x0A7D1B6D, 0x1A3D0B2D, 0x063D172D, 0x16390729, 0x1A7C0B6C, 0x0A3C1B2C, 0x163C072C, 0x06381728, 0x097C1B5C, 0x193C0B1C, 0x053C171C, 0x15380718, 0x196C0A5C, 0x092C1A1C, 0x152C061C, 0x05281618)
# Convert parameters into numpy array
# float32
inpd = np.array(inp, dtype=np.float32)
hpatd = np.array(hpat, dtype=np.uint32)
output = np.empty((n*16), dtype= np.float32)
# float64
inpd = np.array(inp, dtype=np.float64)
output = np.empty((n*16), dtype= np.float64)
# float128
inpd = np.array(inp, dtype=np.float128)
output = np.empty((n*16), dtype= np.float128)
# Get kernel function
matinv4x4 = kernel.get_function("inv4x4")
# Define block, grid and compute
blockDim = (256,1,1) # do not change
gridDim = ((n/16)+1,1,1)
# Kernel function
matinv4x4 (
cuda.In(inpd), cuda.Out(output), np.uint64(n), cuda.In(hpatd),
block=blockDim, grid=gridDim)
return output
As you can see, I tried to increase accuracy of inverting operation by replacing np.float32 by np.float64 or np.float128 but problem remains.
I have also replaced typedef float T; by typedef double T;but without success.
Anyone could help me to perform the right inversion of these matrices and mostly avoid the ‘nan’ and ‘inf’ values ? I think this is a real issue of precision but I can’t find how to circumvent this problem.
Regards
