Hi All,
I’m using the jetson-gpio1 library for controlling the GPIO pins in my Jetson, and it works without any issue.
I want to read the current state(LOW or HIGH) of an output pin using the python jetson-gpio library, But couldn’t find a way to do that.
If I try to do the following on an output pin
GPIO.input(7)
but that didn’t work,
I found that we could directly read the value from
cat /sys/class/gpio/gpio216/value
via the file system, But I’m trying to do that using the python library.
Can someone please help with this ?
~Kasun
