IN NVIDIA_Tegra_Linux_Driver_Package nvl4t_docs, [Kernel Customization]-[Kernel Boot Time Optimization]-[Secondary Bootloader], said:
You can remove uboot as the secondary bootloader to remove boot time of u-boot. The following modifications are required before flashing:
if [ -z “${USE_UBOOT}” ]; then
USE_UBOOT=0;
fi;
It seems that USE_UBOOT is “using_uboot” in Jetpack 3.1.
I set using_uboot=0 in flash.sh, but the uboot still work.
So how can I remove uboot?
I removed the blow code in p2371-2180-devkit.conf:
DFLT_KERNEL_IMAGE=“bootloader/${target_board}/p2371-2180/u-boot.bin”;
Then there is no uboot in boot sequence.
It’s seem worked, but I don’t known whether it has other problem.
Anyone can give me some suggestions?
hello zhili_liu,
may i confirm you’re working this on TX1, right?
the remove u-boot in the documentation is for TX2.
u-boot includes default configuration that enables all supported hardware features,
please refer to [U-Boot Customizatio]->[Optimizing U-Boot Boot Time] to optimize boot time.
thanks
Hi JerryChang,
It’s on TX1.
Do you have method to remove uboot in TX1?
How about method “remove DFLT_KERNEL_IMAGE” to remove uboot in TX1?
Are you attempting to branch directly to Linux kernel execution without a boot loader? If so, there are some serious flaws since device setup and environment expected by the kernel will not be valid. There are things you can do to make U-Boot faster (e.g., not probe for alternate boot media, and not pause for a second or two while waiting for serial console to interrupt)…not having any boot loader at all won’t work since it is not a simple microcontroller.
