hi,
now I encounter a problem when I use v4l2 to catch camera picture.
when I ioctrl(STREAMON), driver prints message like this:
[ 736.430062] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 736.430353] tegra194-vi5 15c10000.vi: vi capture setup failed
I study this problem and find that in function vi_capture_ivc_send_control(),
if (memcmp(&resp_header, &capture->control_resp_msg.header,
sizeof(resp_header)) != 0) {
dev_err(chan->dev,
“unexpected response from camera processor\n”);
err = -EINVAL;
goto fail;
resp_header.msg_id = 0x11(CAPTURE_CHANNEL_SETUP_RESP),
capture->control_resp_msg.header.msg_id = 0x37(CAPTURE_PHY_STREAM_OPEN_RESP)
Is it possible that rtcpu(RCE) has a problem on its side?
Whether the problem can be identified through reset rtcpu or arm cpu separately?
