Hello community,
I encountered a challenge with the ‘launch.sh’ file during the BioNeMo installation process. I created a blank file using the $ sudo nano launch.sh
command at this path (/home/ubuntu) and pasted the script into it.
Script source: Quickstart Guide — NVIDIA BioNeMo Framework
BIONEMO_IMAGE=nvcr.io/nvidia/clara/bionemo-framework:1.1 # Container with tag
LOCAL_REPO_PATH=$(pwd) # This needs to be set to BIONEMO_HOME for local (non-dockerized) use
DOCKER_REPO_PATH=/workspace/bionemo # This is set to BIONEMO_HOME in container
LOCAL_RESULTS_PATH=$(pwd)/results
DOCKER_RESULTS_PATH=/workspace/bionemo/results
LOCAL_DATA_PATH=$(pwd)/data
DOCKER_DATA_PATH=/workspace/bionemo/data
LOCAL_MODELS_PATH=$(pwd)/models
DOCKER_MODELS_PATH=/workspace/bionemo/models
JUPYTER_PORT=8888 # Jupyter port for inference notebooks
REGISTRY=nvcr.io # Only required for registry login
REGISTRY_USER='$oauthtoken' # Only required for registry login
NGC_CLI_API_KEY=$(grep -m 1 apikey ~/.ngc/config | head -n 1 | cut -d' ' -f3) # Requires NGC cli configuration
NGC_CLI_ORG=MyActualOrgName
NGC_CLI_TEAM=MyActualTeamName
NGC_CLI_FORMAT_TYPE=ascii
When I attempted to run it using $ sudo sh launch.sh pull
, it displayed the following output: grep: /root/.ngc/config: No such file or directory
Therefore, I edited this line from:
to:
NGC_CLI_API_KEY=$(grep -m 1 apikey /home/ubuntu/.ngc/config | head -n 1 | cut -d' ' -f3)
Then, I ran $ sudo sh launch.sh pull
again, but nothing showed in the terminal.
How can I fix this issue? What should be expected as terminal output if this script works correctly?
