I followed the Quickstart Guide up to the launch code. This looks like this for me:
BIONEMO_IMAGE=nvcr.io/nvidia/clara/bionemo-framework:1.3 # Container with tag
BIONEMO_PATH=/workspace/bionemo # Location of code to be used /workspace/bionemo or /opt/nvidia/bionemo
PROJECT_PATH=$(pwd) # Path of env config and optional development code
DATA_PATH=${HOME}/data # Local path to save downloaded and processed data
RESULT_PATH=${HOME}/result/bionemo_experiments # Path for training results
WANDB_API_KEY= # WandB logging requires API key configuration
JUPYTER_PORT=8888 # Jupyter port for inference notebooks
PROJECT_MOUNT=/workspace/bionemo # Location of library in container /workspace/bionemo for dev work or /opt/nvidia/bionemo for non-dev use
REGISTRY=nvcr.io # Only required for registry login
REGISTRY_USER=“$oauthtoken” # Only required for registry login
NGC_CLI_API_KEY=$(grep -m 1 apikey ~/.ngc/config | head -n 1 | cut -d’ ’ -f3) # Requires NGC cli configuration
NGC_CLI_ORG=MyActualCliOrg
NGC_CLI_TEAM=
NGC_CLI_FORMAT_TYPE=ascii
when I try to run it using bash launch.sh dev, nothing happens. The container does not start (I check with docker ps), there are no error messages.
- the NGC_CLI_ORG is correct
- permissions are given
Was could be the issue?
