I am using the primary config and ds config in ObjectDetector_fasterRcnn folder along with deepstream_test_app3(python) and getting the following error: Error: gst-library-error-quark: Configuration file parsing failed (5)
following are the deepstream config and primary config file that I am using with test_app3.py. config_infer_primary_fasterRCNN.txt (3.6 KB) dstestrdx_pgie_config.txt (2.3 KB)
Untar the model using: $ tar zxvf faster-rcnn.tgz -C . --strip-components=1 --exclude=ZF_*
Copy the prototxt file “faster_rcnn_test_iplugin.prototxt” from the
** data/faster-rcnn directory in TensorRT samples to this directory.**
Compile the custom library:
** $ make -C nvdsinfer_custom_impl_fasterRCNN**
when I run the command following command I get the following error: gst-launch-1.0 filesrc location=…/…/samples/streams/sample_1080p_h264.mp4 ! *
** decodebin ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 *
** height=1080 ! nvinfer config-file-path= config_infer_primary_fasterRCNN.txt ! **
** nvvideoconvert ! nvdsosd ! nveglglessink sync=0**
ERROR: gst-launch-1.0: symbol lookup error: /home/dipesh/deepstream-5.0/sources/objectDetector_FasterRCNN/nvdsinfer_custom_impl_fasterRCNN/libnvdsinfer_custom_impl_fasterRCNN.so: undefined symbol: createRPNROIPlugin
