Here is the issue:
On my Jetson Nano I have services writing logs and pictures on a USB flash drive for hours without interruption.
Every thing if going fine most of the time but for some of my USB flash drive I can’t write anything on the flash drive for something like 10s every 2s to 10min. Sometimes it’s getting pretty bad and the device is shown as disconnected (not there in /dev, and lsblk).
I found out that the moments were the flash drive is not accessible correspond to the following message in /var/log/kern.log:
Jul 8 16:34:42 nc-ass-vip kernel: [20043.471867] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:35:07 nc-ass-vip kernel: [20069.072184] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:35:23 nc-ass-vip kernel: [20084.432177] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:39:55 nc-ass-vip kernel: [20356.563201] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:40:15 nc-ass-vip kernel: [20377.043089] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:40:46 nc-ass-vip kernel: [20407.754825] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:40:56 nc-ass-vip kernel: [20417.994788] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:41:01 nc-ass-vip kernel: [20423.118702] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:46:09 nc-ass-vip kernel: [20730.314984] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:46:14 nc-ass-vip kernel: [20735.694792] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:50:25 nc-ass-vip kernel: [20986.313611] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:50:30 nc-ass-vip kernel: [20991.686728] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:51:31 nc-ass-vip kernel: [21052.869476] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:51:47 nc-ass-vip kernel: [21068.225470] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:51:52 nc-ass-vip kernel: [21073.349197] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:57:19 nc-ass-vip kernel: [21401.022820] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:57:40 nc-ass-vip kernel: [21421.498433] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:59:17 nc-ass-vip kernel: [21518.776386] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 16:59:33 nc-ass-vip kernel: [21534.139908] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:00:24 nc-ass-vip kernel: [21586.101802] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:00:30 nc-ass-vip kernel: [21591.225602] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:01:11 nc-ass-vip kernel: [21632.184142] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:02:02 nc-ass-vip kernel: [21683.378487] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:07:50 nc-ass-vip kernel: [22031.531224] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
Jul 8 17:08:10 nc-ass-vip kernel: [22052.006684] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
It seems for me that this my USB flash drive are badly corrupted. I can’t get them back to work correctly sudo dosfsck -t -r -v -w /dev/sda1''' don't find any bad sectors. I think it comes from the way my jetson Nano are shutting down as it is done by cutting the power or doing
sudo shutdown now```. I don’t have this issue on a new flash drive.
Is there a system protecting mounted devices on shutdown? Maybe I disrupted the protection doing this:
I changed fstab to automatically mount the flash drive on /media/DEVICE as by default it is mounted on /media/UUID:
cat /etc/fstab
# This fstab is in RAM, the real one can be found at /mnt/root-ro/etc/fstab
# The original entry for '/' and all swap files have been removed. The new
# entry for the read-only the real root fs follows. Write access can be
# enabled using:
# sudo mount -o remount,rw /mnt/root-ro
# re-mounting it read-only is done using:
# sudo mount -o remount,ro /mnt/root-ro
/dev/mmcblk0p1 /mnt/root-ro ext4 ro,relatime,data=ordered 0 0
# remaining entries from the original /mnt/root-ro/etc/fstab follow.
# /etc/fstab: static file system information.
# These are the filesystems that are always mounted on boot, you can
# override any of these by copying the appropriate line from this file into
# /etc/fstab and tweaking it as you see fit. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/sda1 /media/DEVICE vfat defaults,nofail 0 2
cat /mnt/root-ro/etc/fstab
/dev/root / ext4 defaults 0 1
I also changed /etc/udev/rules.d/99-nv-ufs-mount.rules to avoid any conflict changing “sd[a-z][0-9]” to “sd[b-z][0-9]”:
cat /etc/udev/rules.d/99-nv-ufs-mount.rules
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Mount UFS card when detected.
ACTION=="add", KERNEL=="sd[b-z][0-9]", SUBSYSTEM=="block", RUN{program}+="/usr/bin/systemd-mount --no-block --automount=yes --collect $devnode /media/%E{ID_FS_UUID}"
# Unmount UFS card when removed.
ACTION=="remove", KERNEL=="sd[b-z][0-9]", SUBSYSTEM=="block", RUN{program}+="/usr/bin/systemd-umount /media/%E{ID_FS_UUID}"
I never retrieve usb flash drive without unmouting it or being sure it is shut down.
Could you give me a clue on what’s going on? Maybe a better was to automount the first flash drive were I want?
