Hello to everyone.
During the last 3 days I tried to boot my nano again,but it always failed. I have two sd cards. The first one is 200 GB large ; the second one is 120 gb large. I’ve used the first one for a long time booting the nano from USB and it always worked. I have written on both the sd cards the “jetson-nano-jp461-sd-card-image-b01.img” img file using dd. I have always used the kiwibird sd card to usb adapter,for the first and the second one without problems. But on the last 3 days the situation changed. Im not able anymore to boot the sd cards. No matter what I do,they won’t boot. Below you can read the log captured by minicom :
U-Boot 2020.04-g4335beb (Nov 22 2022 - 09:21:37 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, eB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
Card did not respond to voltage select!
starting USB...
Bus usb@7d000000: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
Bus xusb@70090000: Loading XUSB FW blob from RP4 partition ...
SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
Firmware size 126464
Firmware timestamp: 0x5f23e558, Version: 50.26 release
Register HCSParams1: 9000124 NbrPorts: 9
Starting the controller
USB XHCI 1.00
scanning bus xusb@70090000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-tegra210-p3450-0000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Tegra210 (P3450-0000) #
I don’t understand what’s the error.
