This is the log file i got
SDKM_logs_JetPack_4.6.4_Linux_for_Jetson_Nano_modules_2024-01-06_09-55-19.zip (181.6 KB)
09:55:23 SUMMARY: CUDA on Host - host: Install completed successfully.
09:55:23 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
09:55:23 SUMMARY: VisionWorks on Host - host: Install completed successfully.
09:55:23 SUMMARY: VPI on Host - host: Install completed successfully.
09:55:23 SUMMARY: Nsight Graphics - host: Install completed successfully.
09:55:23 SUMMARY: Nsight Systems - host: Install completed successfully.
09:55:23 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
09:55:23 SUMMARY: File System and OS - target_image: Install completed successfully.
09:55:47 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(401)
09:55:48 ERROR: Flash Jetson Nano - flash: /home/varun/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 2661: [: : integer expression expected
09:56:40 ERROR: Flash Jetson Nano - flash: 1+0 records in
09:56:40 ERROR: Flash Jetson Nano - flash: 1+0 records out
09:56:40 ERROR: Flash Jetson Nano - flash: 1 byte copied, 3.6627e-05 s, 27.3 kB/s
09:56:40 ERROR: Flash Jetson Nano - flash: 1 byte copied, 3.6001e-05 s, 27.8 kB/s
09:56:40 ERROR: Flash Jetson Nano - flash: 4+0 records in
09:56:40 ERROR: Flash Jetson Nano - flash: 4+0 records out
09:56:40 ERROR: Flash Jetson Nano - flash: 4 bytes copied, 4.0669e-05 s, 98.4 kB/s
09:56:41 ERROR: Flash Jetson Nano - flash: Error: Return value 8
09:56:41 ERROR: Flash Jetson Nano - flash: Failed flashing t210ref.
09:56:41 ERROR: Flash Jetson Nano - flash: *** ERROR: flashing failed.
09:56:41 ERROR: Flash Jetson Nano - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.varun.sh; [error]: *** ERROR: flashing failed.
09:56:41 ERROR: Flash Jetson Nano - flash: command terminated with error
09:56:41 SUMMARY: Flash Jetson Nano - flash: First Error: Installation failed.
09:56:41 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
09:56:41 SUMMARY: Multimedia API - target: Depends on failed component
09:56:41 SUMMARY: TensorRT on Target - target: Depends on failed component
09:56:41 SUMMARY: VisionWorks on Target - target: Depends on failed component
09:56:41 SUMMARY: VPI on Target - target: Depends on failed component
09:56:41 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
09:56:41 SUMMARY: cuDNN on Target - target: Depends on failed component
09:56:41 SUMMARY: OpenCV on Target - target: Depends on failed component
09:56:41 SUMMARY: Nsight Systems CLI - target: Depends on failed component
09:56:41 SUMMARY: DeepStream - target: Depends on failed component
09:56:41 SUMMARY: DateTime Target Setup - target: Depends on failed component
10:03:54 SUMMARY: CUDA on Host - host: Install completed successfully.
10:03:54 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
10:03:54 SUMMARY: VisionWorks on Host - host: Install completed successfully.
10:03:54 SUMMARY: VPI on Host - host: Install completed successfully.
10:03:54 SUMMARY: Nsight Graphics - host: Install completed successfully.
10:03:54 SUMMARY: Nsight Systems - host: Install completed successfully.
10:04:03 ERROR: shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
10:04:30 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
10:09:04 SUMMARY: File System and OS - target_image: Install completed successfully.
10:09:29 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(401)
10:09:30 ERROR: Flash Jetson Nano - flash: /home/varun/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 2661: [: : integer expression expected
10:10:28 ERROR: Flash Jetson Nano - flash: 1+0 records in
10:10:28 ERROR: Flash Jetson Nano - flash: 1+0 records out
10:10:28 ERROR: Flash Jetson Nano - flash: 1 byte copied, 4.1336e-05 s, 24.2 kB/s
