• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4-b144
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
Dear All,
I have been experiencing crashes in Jetson nano for a couple of years now.
After a random number of days with very little stress on the board (not even using the GPU), the system get stuck after a self-reboot.
Apparently, nothing gets logged after the reboot procedure.
The syslog contains only the entries from the kernel log.
This is an extract of kernel log from a normal boot:
Oct 15 16:15:27 jnano-desktop kernel: [ 25.007166] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 15 16:15:29 jnano-desktop kernel: [ 27.375455] zram: Added device: zram0
Oct 15 16:15:29 jnano-desktop kernel: [ 27.375862] zram: Added device: zram1
Oct 15 16:15:29 jnano-desktop kernel: [ 27.376234] zram: Added device: zram2
Oct 15 16:15:29 jnano-desktop kernel: [ 27.376598] zram: Added device: zram3
Oct 15 16:15:29 jnano-desktop kernel: [ 27.397458] zram0: detected capacity change from 0 to 519585792
Oct 15 16:15:29 jnano-desktop kernel: [ 27.521702] Adding 507404k swap on /dev/zram0. Priority:5 extents:1 across:507404k SS
Oct 15 16:15:29 jnano-desktop kernel: [ 27.524794] zram1: detected capacity change from 0 to 519585792
Oct 15 16:15:29 jnano-desktop kernel: [ 27.535941] Adding 507404k swap on /dev/zram1. Priority:5 extents:1 across:507404k SS
Oct 15 16:15:29 jnano-desktop kernel: [ 27.539100] zram2: detected capacity change from 0 to 519585792
Oct 15 16:15:29 jnano-desktop kernel: [ 27.549878] Adding 507404k swap on /dev/zram2. Priority:5 extents:1 across:507404k SS
Oct 15 16:15:29 jnano-desktop kernel: [ 27.552926] zram3: detected capacity change from 0 to 519585792
Oct 15 16:15:29 jnano-desktop kernel: [ 27.568009] Adding 507404k swap on /dev/zram3. Priority:5 extents:1 across:507404k SS
Oct 15 16:15:31 jnano-desktop kernel: [ 29.082315] r8168: eth0: link up
Oct 15 16:15:31 jnano-desktop kernel: [ 29.082359] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 15 16:15:46 jnano-desktop kernel: [ 43.762370] tegradc tegradc.0: blank - powerdown
Oct 15 16:15:46 jnano-desktop kernel: [ 43.762380] tegradc tegradc.1: blank - powerdown
Oct 15 16:15:53 jnano-desktop kernel: [ 51.233314] Bridge firewalling registered
Oct 15 16:15:53 jnano-desktop kernel: [ 51.612068] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Oct 15 16:15:54 jnano-desktop kernel: [ 52.541180] Netfilter messages via NETLINK v0.30.
Oct 15 16:15:54 jnano-desktop kernel: [ 52.549235] ctnetlink v0.93: registering with nfnetlink.
Oct 15 16:15:55 jnano-desktop kernel: [ 52.937662] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
Oct 15 16:15:59 jnano-desktop kernel: [ 57.638081] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Oct 15 16:15:59 jnano-desktop kernel: [ 57.638092] Bluetooth: BNEP socket layer initialized
Oct 15 16:16:00 jnano-desktop kernel: [ 58.327758] fuse init (API version 7.26)
Oct 15 16:16:08 jnano-desktop kernel: [ 66.717560] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
Oct 15 16:16:08 jnano-desktop kernel: [ 66.729308] EXT4-fs (mmcblk0p1): recovery complete
Oct 15 16:16:08 jnano-desktop kernel: [ 66.731465] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Oct 15 16:16:33 jnano-desktop kernel: [ 91.154819] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
Instead, this is the last part of the kernel log from the faulty boot procedure:
Oct 14 22:51:27 jnano-desktop kernel: [ 24.071307] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 14 22:51:29 jnano-desktop kernel: [ 26.085068] zram: Added device: zram0
Oct 14 22:51:29 jnano-desktop kernel: [ 26.085674] zram: Added device: zram1
Oct 14 22:51:29 jnano-desktop kernel: [ 26.088345] zram: Added device: zram2
Oct 14 22:51:29 jnano-desktop kernel: [ 26.089650] zram: Added device: zram3
Oct 14 22:51:29 jnano-desktop kernel: [ 26.119664] zram0: detected capacity change from 0 to 518537216
Oct 14 22:51:29 jnano-desktop kernel: [ 26.169756] Adding 506380k swap on /dev/zram0. Priority:5 extents:1 across:506380k SS
Oct 14 22:51:29 jnano-desktop kernel: [ 26.173432] zram1: detected capacity change from 0 to 518537216
Oct 14 22:51:29 jnano-desktop kernel: [ 26.195861] Adding 506380k swap on /dev/zram1. Priority:5 extents:1 across:506380k SS
Oct 14 22:51:29 jnano-desktop kernel: [ 26.216176] zram2: detected capacity change from 0 to 518537216
Oct 14 22:51:29 jnano-desktop kernel: [ 26.251188] Adding 506380k swap on /dev/zram2. Priority:5 extents:1 across:506380k SS
Oct 14 22:51:29 jnano-desktop kernel: [ 26.260994] zram3: detected capacity change from 0 to 518537216
Oct 14 22:51:29 jnano-desktop kernel: [ 26.275883] Adding 506380k swap on /dev/zram3. Priority:5 extents:1 across:506380k SS
Oct 14 22:51:31 jnano-desktop kernel: [ 28.154587] r8168: eth0: link up
Oct 14 22:51:31 jnano-desktop kernel: [ 28.155008] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 14 22:51:47 jnano-desktop kernel: [ 43.568707] tegradc tegradc.0: blank - powerdown
Oct 14 22:51:47 jnano-desktop kernel: [ 43.631766] extcon-disp-state extcon:disp-state: cable 47 state 0
Oct 14 22:51:47 jnano-desktop kernel: [ 43.631769] Extcon AUX1(HDMI) disable
Oct 14 22:51:47 jnano-desktop kernel: [ 43.652225] tegradc tegradc.0: unblank
Oct 14 22:51:47 jnano-desktop kernel: [ 43.665053] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
Oct 14 22:51:47 jnano-desktop kernel: [ 43.665138] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
Oct 14 22:51:47 jnano-desktop kernel: [ 43.666822] tegradc tegradc.0: hdmi: get RGB quant from EDID.
Oct 14 22:51:47 jnano-desktop kernel: [ 43.666829] tegradc tegradc.0: hdmi: get YCC quant from EDID.
Oct 14 22:51:47 jnano-desktop kernel: [ 43.701606] extcon-disp-state extcon:disp-state: cable 47 state 1
Oct 14 22:51:47 jnano-desktop kernel: [ 43.701609] Extcon AUX1(HDMI) enable
Oct 14 22:51:47 jnano-desktop kernel: [ 43.707836] tegradc tegradc.0: unblank
Oct 14 22:51:47 jnano-desktop kernel: [ 43.708249] tegradc tegradc.1: blank - powerdown
Oct 14 22:51:51 jnano-desktop kernel: [ 48.352863] Bridge firewalling registered
Oct 14 22:51:51 jnano-desktop kernel: [ 48.390972] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Oct 14 22:51:52 jnano-desktop kernel: [ 48.997819] Netfilter messages via NETLINK v0.30.
Oct 14 22:51:52 jnano-desktop kernel: [ 49.001449] ctnetlink v0.93: registering with nfnetlink.
Oct 14 22:51:52 jnano-desktop kernel: [ 49.377000] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
The difference I notice is that nothing is said about the FS mounting.
Do you have any idea why the Jetson Nano behaves like that?
Thanks in advance!
